Hi
My photon has a strange behaviour:
When the photon is unplugged from the power source for a long time (12 hours) and then started again, it’s blinking blue (listening mode). I’m using an external antenna because internal antenna doesnt work. Any advice?
My code:
#include <Wire.h>
#include <Adafruit_SSD1306.h>
#include <Adafruit_GFX.h>
// OLED display TWI address
#define OLED_ADDR 0x3C
Adafruit_SSD1306 display(-1);
#if (SSD1306_LCDHEIGHT != 64)
#error("Height incorrect, please fix Adafruit_SSD1306.h!");
#endif
float tempf;
float tempc;
float humidity;
float inches;
int altitude = 79;
double pot3;
float pot2;
float pot1;
float pressurehpa;
char id[] = "xxxxx";
char pwd[] = "xxxxxx";
char data[180];
#include "Adafruit_Sensor.h"
#include "Adafruit_BME280.h"
#define BME_SCK D0
#define BME_MISO D3
#define BME_MOSI D2
#define BME_CS D1
char* SSID = "xxxxxx";
char* PASSWORD = "xxxxxx";
#define SEALEVELPRESSURE_HPA (1013.25)
Adafruit_BME280 bme; // I2C
//Adafruit_BME280 bme(BME_CS); // hardware SPI
//Adafruit_BME280 bme(BME_CS, BME_MOSI, BME_MISO, BME_SCK);
SYSTEM_THREAD(ENABLED);
SYSTEM_MODE(SEMI_AUTOMATIC);
STARTUP(WiFi.selectAntenna(ANT_EXTERNAL));
int VaneValue;// raw analog value from wind vane
int Direction;// translated 0 - 360 direction
int CalDirection;// converted value with offset applied
int LastValue;
#define Offset 0;
#include <math.h>
#define WindSensorPin (D6) // The pin location of the anemometer sensor
volatile unsigned long Rotations; // cup rotation counter used in interrupt routine
volatile unsigned long ContactBounceTime; // Timer to avoid contact bounce in interrupt routine
float WindSpeed; // speed miles per hour
float WindSpeedkt;
int displays = 0;
// initialize and clear display
LastValue = 1;
Serial.println(F("BME280 test"));
pinMode(WindSensorPin, INPUT);
WiFi.on();
WiFi.disconnect();
WiFi.clearCredentials();
WiFi.setCredentials(SSID, PASSWORD);
WiFi.connect();
waitUntil(WiFi.ready);
Particle.connect();
display.begin(SSD1306_SWITCHCAPVCC, OLED_ADDR);
display.clearDisplay();
display.display();
if (!bme.begin(0x76)) {
Serial.println("Could not find a valid BME280 sensor, check wiring!");
display.setTextSize(5);
display.setTextColor(WHITE);
display.setCursor(0,0);
display.print("N/A");
display.display();
// put your main code here, to run repeatedly:
// display a line of text
Rotations = 0; // Set Rotations count to 0 ready for calculations
attachInterrupt(WindSensorPin, isr_rotation, FALLING);
delay(3000);
detachInterrupt(WindSensorPin);
// convert to mp/h using the formula V=P(2.25/T)
// V = P(2.25/3) = P * 0.75
WindSpeed = Rotations * 0.75;
WindSpeedkt = WindSpeed / 1.151;
VaneValue = analogRead(A4);
Direction = map(VaneValue, 0, 4095, 0, 360);
CalDirection = Direction + Offset;
if(CalDirection > 360)
CalDirection = CalDirection - 360;
if(CalDirection < 0)
CalDirection = CalDirection + 360;
tempc = bme.readTemperature();
tempf = tempc * 1.8 + 32;
humidity = bme.readHumidity();
pressurehpa = (bme.readPressure() / 100.0F);
inches = 0.02952998751 * pressurehpa;
float a = 17.271;
float b = 237.7;
float taupunktTemp = (a * bme.readTemperature()) / (b + bme.readTemperature()) + log(humidity/100);
float pPre= (b * taupunktTemp) / (a - taupunktTemp);
float pf = pPre * 1.8 + 32;
pot1 = 1 - 0.0065 * altitude / (bme.readTemperature() + 0.0065 * altitude + 273.15);
pot2 = (0.03416 / 0.0065);
pot3 = pow(pot1,pot2);
float relhpa = pressurehpa / pot3;
float relinches = 0.02952998751 * relhpa;
displays = displays + 1;
if (displays > 3) {
displays = 0;
if ((displays == 0) or (displays == 1)) {
display.setTextSize(2);
display.print(tempc,1);
display.print(" Grad");
display.setCursor(0,20);
display.print(WindSpeedkt,1);
display.print(" kt");
display.setCursor(0,40);
display.print(CalDirection);
display.print(" deg");
// update display with all of the above graphics
display.display();
if ((displays == 2) or (displays == 3)) {
display.print(pressurehpa,2);
display.print(" hP");
display.print(humidity,1);
display.print(" %");
display.display();
snprintf(data, sizeof(data)
,"{\"id\":\"%s\""
",\"pw\":\"%s\""
",\"dt\":\"%s\""
",\"tf\":\"%.1f\""
",\"hum\":\"%.1f\""
",\"baro\":\"%.2f\""
",\"tau\":\"%.1f\""
",\"wsm\":\"%.1f\""
",\"wd\":\"%.d\""
,id
,pwd
,"now"
,tempf
,humidity
,relinches
,pf
,WindSpeed
,CalDirection
Particle.publish("spanienwunderground", data, PRIVATE);
void isr_rotation () {
if ((millis() - ContactBounceTime) > 15 ) { // debounce the switch contact.
Rotations++;
ContactBounceTime = millis();
When i then try again it’s very often the same but sometimes it’s working fine…
Can I disable listening mode during startup or is there an other solution?
