Does anyone have any advice regarding external enclosures?
I’ve been making a couple of solar powered soil sensors with Xenons, one for the garden one for the greenhouse. I need to make an enclosure to protect them, but I am also doing environmental monitoring including humidity. Clearly that will not work if I go for a high IP rating.
I was going to design print the enclosure myself. If I have the xenon and battery in an enclosure with vented sides, is it likely to last long? Or, is it better to go for a split thing where the humidity sensor is in a vented part and the rest of the project in a more sealed section with the wires running out? I did wonder if I go for the latter if there are any over heating issues to consider or if any moisture does get in it will not dry out as easily. I’m in England where we specialize in drizzle.
If you mean having your humidity sensor inside your IP rated enclosure - correct.
I am in England as well - I have a Photon controlling my driveway lights - it is sat inside a commercial IP rated junction box from ScrewFix with sealed/gland wire entries from sensors - no overheating issues and no other issues for the past 2 years that it has been working.
Yeah, that is it. I didn’t know if I should split the project into two boxes, one protected and a vented cover for the sensor, or just vent the whole lot.
I used to work for a company where we made our own remote telemetry equipment, stuff that went into some pretty terrible environments. There were a couple of things. This makes me think cause I actually want to build a simple little weather station for myself. TBH I was just going to poke a hole in the bottom of an electrical box and call it a day.
The first was that all the equipment PCBs were conformally coated. I wonder if you could get some kind of conformal coating in a can. To be honest, sometimes small parts were just encased in silicone. Even if you could spray everything with a thin layer of silicone that would be alright.
The second part was that for remote sensors the sensor was separate from the electronics. So ya, like a sealed housing with a sensor coming through to measure what it had to measure.
Point of interest on this topic. For the sensors which went into really tough environments, we found that if the housing was completely sealed it would actually fill up with water. The only thing we could think of was the constant heating/cooling cycle of it being in the sun, maybe some humidity permeating and then condensing. The only solution was to use a little vent made of some kind of GORE-TEX which let moisture go only one way.
Thanks for all the suggestions. I think trying to print something watertight is going to be difficult and likely pointless as there are watertight enclosures available fairly cheap. I think what I will do is use a small IP65 enclosure for the xenon, prototyping board and battery, but from @doublepointer’s advice, install a water leak detector in the bottom (or even two exposed wires might do the job). I’ll make a separate angled enclosure for the solar panel and install the environment sensor underneath that. I was going to have to put in a hole and run cables for the soil moisture sensor, so no big deal if there are a few more. I’ll seal those up with hot glue or silicone seal.
I’ve got some PCB varnish so I’ll give everything a good coating with that too. Having the solar panel separate might allow me to put it in a more optimal place too.
As this is for a greenhouse and veg garden, I probably should bring them in during the winter anyway. It is England, the ground drying out in the winter is really not a problem that needs a tech solution! The cold will not do the batteries any good.
