Enable BIP and STK for External SIM on Boron
Hello,
We are using sims that need BIP and STK turned on for their eSIM heartbeats. Is it possible to turn this on in the Boron? I assume it would be an AT command to run when setting the APN?
Best,
Owen
STK should be enabled by default, but if your SIM requires BIP notifications you will probably need to enable it using the AT+UBIP command.
See the u-blox R410 AT commands manual, section 12.
Use Cellular.command to send the command.
Hi Rick,
Thanks! I think that did the trick!
Best,
Owen
