Boron flashing blu(like listening mode) activate internal sim card with particle cli command?
Hello
After some action to restore Boron from a stade led flashing blue and not possibility to reconnect to the cloud, I ask the support if is possible to activate the internal sim card with a particle cli command? I have activate the 3rd sim card (Cellular.setActiveSim(EXTERNAL_SIM))
For your information if I use the cellular to reconnect by enroll I receive the error:request failed: not found (404).
Can any people give my a suggestion to restore the Boron?
Thanks Valentino
Did you get an answer?
The docs provide a way to do via code
Cellular.setActiveSim(INTERNAL_SIM);
( https://docs.particle.io/reference/device-os/firmware/boron/#setactivesim- )
But when you have activated the external SIM you probably also have set new credentials via Cellular.setCredentials() which is a persistent setting. Consequently you have to clear these too via
// Clears any existing credentials. Use this to restore the use of the Particle SIM.
Cellular.clearCredentials();
( https://docs.particle.io/reference/device-os/firmware/boron/#setcredentials- )
But in order to have these commands executed before entering Listening Mode, you probably want them in a STARTUP() macro or in a SYSTEM_MODE(SEMI_AUTOMATIC) project.
In order to flash that reset code you can use DFU Mode particle flash --usb <yourReset.bin>
Next I will try your suggestion, I don’t have ask the support I made write wrong, I have intend the community.
For the moment thanks, I appreciate your help.
Valentino
Hello Mr. ScurffR good news! Thanks for your support and suggestion. For your information I use this procedure and everything works fine:
Setting up a 3rd-party SIM card - Boron
Boron is alive!
Grazie di cuore
Valentino
