I didn’t think the Boron LTE would work with Google Fi, but it did. I was about to call it as not working but after a few minutes it connected and it’s now happily breathing cyan.
I used this firmware, which is Tinker with the APN setting:
#include "Particle.h"
#include "dct.h"
SYSTEM_MODE(SEMI_AUTOMATIC);
SerialLogHandler logHandler(LOG_LEVEL_ALL);
/* Function prototypes -------------------------------------------------------*/
int tinkerDigitalRead(String pin);
int tinkerDigitalWrite(String command);
int tinkerAnalogRead(String pin);
int tinkerAnalogWrite(String command);
/* This function is called once at start up ----------------------------------*/
//Setup the Tinker application here
Cellular.setActiveSim(EXTERNAL_SIM);
Cellular.setCredentials("h2g2");
// This clears the setup done flag on brand new devices so it won't stay in listening mode
const uint8_t val = 0x01;
dct_write_app_data(&val, DCT_SETUP_DONE_OFFSET, 1);
//Register all the Tinker functions
Particle.function("digitalread", tinkerDigitalRead);
Particle.function("digitalwrite", tinkerDigitalWrite);
Particle.function("analogread", tinkerAnalogRead);
Particle.function("analogwrite", tinkerAnalogWrite);
Particle.keepAlive(30);
Particle.connect();
/* This function loops forever --------------------------------------------*/
//This will run in a loop
* Function Name : tinkerDigitalRead
* Description : Reads the digital value of a given pin
* Input : Pin
* Output : None.
* Return : Value of the pin (0 or 1) in INT type
Returns a negative number on failure
//convert ASCII to integer
int pinNumber = pin.charAt(1) - '0';
//Sanity check to see if the pin numbers are within limits
if (pinNumber < 0 || pinNumber > 7) return -1;
if(pin.startsWith("D"))
pinMode(pinNumber, INPUT_PULLDOWN);
return digitalRead(pinNumber);
else if (pin.startsWith("A"))
pinMode(pinNumber+10, INPUT_PULLDOWN);
return digitalRead(pinNumber+10);
#if Wiring_Cellular
else if (pin.startsWith("B"))
if (pinNumber > 5) return -3;
pinMode(pinNumber+24, INPUT_PULLDOWN);
return digitalRead(pinNumber+24);
else if (pin.startsWith("C"))
if (pinNumber > 5) return -4;
pinMode(pinNumber+30, INPUT_PULLDOWN);
return digitalRead(pinNumber+30);
#endif
return -2;
* Function Name : tinkerDigitalWrite
* Description : Sets the specified pin HIGH or LOW
* Input : Pin and value
* Output : None.
* Return : 1 on success and a negative number on failure
bool value = 0;
int pinNumber = command.charAt(1) - '0';
if(command.substring(3,7) == "HIGH") value = 1;
else if(command.substring(3,6) == "LOW") value = 0;
else return -2;
if(command.startsWith("D"))
pinMode(pinNumber, OUTPUT);
digitalWrite(pinNumber, value);
return 1;
else if(command.startsWith("A"))
pinMode(pinNumber+10, OUTPUT);
digitalWrite(pinNumber+10, value);
return 1;
#if Wiring_Cellular
else if(command.startsWith("B"))
pinMode(pinNumber+24, OUTPUT);
digitalWrite(pinNumber+24, value);
return 1;
else if(command.startsWith("C"))
if (pinNumber > 5) return -5;
pinMode(pinNumber+30, OUTPUT);
digitalWrite(pinNumber+30, value);
return 1;
#endif
else return -3;
* Function Name : tinkerAnalogRead
* Description : Reads the analog value of a pin
* Input : Pin
* Output : None.
* Return : Returns the analog value in INT type (0 to 4095)
return -3;
return analogRead(pinNumber+10);
#if Wiring_Cellular
if (pinNumber < 2 || pinNumber > 5) return -3;
return analogRead(pinNumber+24);
#endif
return -2;
* Function Name : tinkerAnalogWrite
* Description : Writes an analog value (PWM) to the specified pin
* Input : Pin and Value (0 to 255)
* Output : None.
String value = command.substring(3);
if(command.substring(0,2) == "TX")
pinMode(TX, OUTPUT);
analogWrite(TX, value.toInt());
return 1;
else if(command.substring(0,2) == "RX")
pinMode(RX, OUTPUT);
analogWrite(RX, value.toInt());
return 1;
analogWrite(pinNumber, value.toInt());
return 1;
analogWrite(pinNumber+10, value.toInt());
return 1;
else if(command.substring(0,2) == "TX")
return 1;
return 1;
#if Wiring_Cellular
else if (command.startsWith("B"))
if (pinNumber > 3) return -3;
analogWrite(pinNumber+24, value.toInt());
return 1;
else if (command.startsWith("C"))
if (pinNumber < 4 || pinNumber > 5) return -4;
analogWrite(pinNumber+30, value.toInt());
return 1;
#endif
else return -2;
