I’m having some trouble flashing two electrons with my app code. I’ve used the particle workbench plugin for compiling and flashing. Whenever I put the electron in DFU mode and flash it appears to flash correctly but doesn’t as the old code is present.
Strangely whenever I compile and flash for debug the app code does flash correctly.
The OS version on both boards is 1.5.2.
For context before I tried flashing my app code I used the web IDE update the device OS from 0.5.x to 1.5.2.
Any idead on why this might be happening?
Many thanks
