Electron with Australia Telstra Sim and Sending SMS
Just recently I did something like that for another project
SYSTEM_MODE(SEMI_AUTOMATIC)
SYSTEM_THREAD(ENABLED)
STARTUP(cellular_credentials_set("yourAPN", "", "", NULL))
SerialLogHandler serlog;
#define RADIO Cellular
int placeCall(const char* telNr, uint32_t duration = 30000);
int sendMessage(const char* telNr, const char* msg);
  RADIO.on();
  RADIO.connect();
  Particle.connect();
  static uint32_t ms = 0;
  if (millis() - ms > 60000) {
    ms = millis();
    placeCall("+##########");  // target phone number international format
    sendMessage("+########", "Hi there, I'm Electron!");
  int  ret;
  char cmd[64];
  if (!RADIO.ready())
    RADIO.on();
    RADIO.connect();
    if (!waitFor(RADIO.ready, 300000))
      Log.warn("no radio connection");
      return -1;
  ret = Cellular.command("AT+CMGF=1\r\n");
  ret = Cellular.command("AT+CMGS=\"%s%s\",145\r\n", (telNr[0] != '+') ? "+" : "", telNr);
  ret = Cellular.command("%s\x1a", msg);
  switch (ret)
    case WAIT:
      Log.info("WAITING, but probably");
    case RESP_OK:
      Log.info("Sent: '%s' to %s", msg, telNr);
      break;
    default:
      Log.warn("Message not sent (%d)", ret);
      break;
  return ret;
int placeCall(const char* telNr, uint32_t duration)
  int  ret;
  if (!RADIO.ready())
    RADIO.on();
    RADIO.connect();
      return -1;
  if ((ret = Cellular.command("ATD%s;\r\n", telNr)) == RESP_OK)
    Log.info("Call pending");
    softDelay(duration);
    Cellular.command("AT+CHUP\r\n");
    Log.info("Hung up");
  else
    Log.warn("Call not possible (%d)", ret);
  return ret;
inline void softDelay(uint32_t msDelay)
  for (uint32_t ms=millis(); millis()-ms < msDelay; Particle.process());
