So… does the Electron SIM card support SMS text messages? I’ve run several codes I found that send text messages and it loads fine and the trigger circuits work fine but I’ve yet to get a text message. I’ve done some searching on the forums and found people sending but I’ve also found a few posts showing the stock SIM card doesn’t support sending Text message. If that’s true then what SIM card do you recommend using to send a simple Text message? AND… is there a simple code snippet showing an example of sending a text message? Anyone know where I’d begin looking outside what I’ve already found? Thanks
The Particle SIM doesn’t support text (for now?). You can use almost any other 3rd party SIM card, but you’ll have to keep the keep-alive times in mind (which vary per provider).
I guess this thread is now superceeded by this one of yours (which you actually posted earlier) - double posting is frowned upon here, even if it's not exactly but mainly the same thing twice
