I recently noticed a weird behavior of my testing electron. After doing a manual firmware update via usb (orange flashing light of electron) my electron didn’t behave as it should be even the update process states a Flash Success. Then I tried to install tinker with the following log but also than my old user firmware is running. Any ideas?
Tried with 0.5.3 and 0.6.0 (for me currently 0.5.3 is better as my electrons in the field are on 0.5.3). Somehow I got it to work but after pressing the reset button the old firmware was there again. I also searched for factory reset but as I understood this is not possible anymore.
Any help appreciated!
$ particle flash --usb tinker
Found DFU device 2b04:d00a
spawning dfu-util -d 2b04:d00a -a 0 -i 0 -s 0x08080000:leave -D /usr/local/lib/node_modules/particle-cli/binaries/electron_tinker.bin
dfu-util 0.9
Deducing device DFU version from functional descriptor length
ID 2b04:d00a
Claiming USB DFU Interface...
dfuIDLE, continuing
Downloading to address = 0x08080000, size = 5776
Download [=========================] 100% 5776 bytes
Download done.
File downloaded successfully
Flash success!
Maybe you download the three 0.5.3 system binaries flash them via CLI in order (or inverse order if you already have a higher version installed) and then try again --usb tinker
I tried (btw you mean 2 parts for 0.5.3, right?). The result is one more time very surprising. The Output:
$ dfu-util -d 2b04:d006 -a 0 -s 0x8020000 -D system-part1-0.5.3-electron.bin
dfu-util 0.9
ID 2b04:d00a
dfuIDLE, continuing
Downloading to address = 0x08020000, size = 122916
Download [=========================] 100% 122916 bytes
Download done.
$ dfu-util -d 2b04:d006 -a 0 -s 0x8060000:leave -D system-part2-0.5.3-electron.bin
dfu-util 0.9
ID 2b04:d00a
dfuIDLE, continuing
Downloading to address = 0x08060000, size = 122436
Download [=========================] 100% 122436 bytes
Download done.
Now the interesting thing is I had not to install tinker again, it booted directly the Tinker App. Great, than I wanted to install my own Firmware with particle flash --usb firmware.bin and of course it didn’t work. I made a 2nd firmware update to 0.5.3 but it still booted with tinker. So I am still confused and not sure what is wrong here.
$ particle serial inspect
! serial: No serial port identified
The problem here is that I can not get into Listening Mode with that device at the moment. When I just press the Mode Button for 3 seconds it ended up in DFU Mode (orange blinking) and for my understanding I need Listening Mode to get this command working, right? Or is Listening Mode not available with tinker? Thats very weird cause I know normally pressing Mode + shortly Reset ends up in DFU Mode. Yesterday with my old firmware it worked to getting manually in Listening Mode (3s Mode Button) but not with tinker at the moment.
$ particle binary inspect firmware.bin
firmware.bin
CRC is ok (2a7d7d7a)
Compiled for electron
This is an application module number 1 at version 4
It depends on a system module number 2 at version 21
Short Information on top:
What I also found out is that the device is of course in console.particle.io but then yesterday I downloaded the particle app to test out tinker (never tried before) and there this named device does not appear even when I pull to refresh. Than it was shortly in the list after reopening the App but with one more pull to refresh it was gone again… so on the Electron the tinker shows with the led is permanent on (with white, maybe blue and red light)?
Mh that does not work for me. I tried to remove SIM while electron has no power --> doesn't go to listening mode. Tried to press mode button for longer time ends up in DFU Mode as well.
Than I inserted and removed the SIM with power --> doesn't force electron to enter listening mode.
So till now no chance to perform the command $ particle serial inspect with success.
So I will contact official support as you mentioned, thanks. Because it is neither possible to go into listening mode nor flash a new firmware successfully with DFU Mode.
@kennethlimcp I bought another 50 electrons and I noticed that it is the same behaviour for one more electron. Is this a know Issue that can happen?
I upgraded from 0.5.3 to 0.6.1 and vice versa but it seems that it never takes my own user firmware. how could that be? to be honest that is not very trustful to use particle.
Are there any other hints how that could be fixed? To be honest I don’t want to wait to get a replacement, rather I would fix it as soon as possible by my own if there are other possibilites.
