I’m building a IoT device that will work indoors and I use an Electron for connectivity.
The Electron has a handy feature, where if you press the ‘mode’ button once it’s breating blue it will flash the signal strength in a series of green lights
I need to reproduce this logic using 5 LEDs on my device, so that a user can visually see the indoor signal strength as they move the device around and decide where best to place it (i.e. so they can place it with someplace with a strong signal)
But can you please let me know what Algorithm/logic you use to translate the RSSI returned via the API into a 1-5 scale? so I can mirror the built-in, “mode” feature in my own 5 LED setup. I’d like to mirror this exactly so I’m confident in the logic.
The CellularSignal sig = Cellular.RSSI(); is giving me an error so not even able to get to the loop on printing out the strength, I was also wondering if this can be done in a case instead of all the if’s. Any help is welcome, Thank You
Understand did mean to, I did get the code to verify after fixing bunch of things
instead of trying to use char or arrays I just had it do a print out Serial.write for the different setting I wanted. Thank You tho for looking at it.
system_display_rssi();
void system_display_rssi() {
int rssi = 0;
#if Wiring_WiFi == 1
rssi = WiFi.RSSI();
#elif Wiring_Cellular == 1
rssi = sig.rssi;
#endif
if (rssi < 0) {
if (rssi>=-70){Serial.write("Excellent"); }
else if(rssi>=-70 && rssi >-85) {Serial.write("Good");}
else if (rssi>-86&& rssi >=-100) {Serial.write("Fair");}
else if (rssi>-100) {Serial.write("Poor");}
else if (rssi>-110) {Serial.write("No Signal");}
The logic here will not work as you expect; the first else-if statement will never be executed. If rssi >= -70, the if statement will run, so the else-if statement will never be reached. The other conditions aren't correct either. For instance, if rssi == -71, you would want the result to be "Good", but given your logic, it would print "Fair". You don't need to "AND" any of the conditions together, you only need one condition for each statement. Something like this should do,
if (rssi < 0) {
if (rssi >= -70) {
}else if(rssi >= -85) {
}else if (rssi >= -100) {
}else {
I can’t get my sketch to compile and I wondered if I need to add additional libraries for ‘system_display_bars’?
Would it be possible to display the Strength using an I2C 16x2 LCD Display using the lcd.print (char…) after defying the 5 chars? I’m not sure how this line displays the data, DEBUG(“RSSI: %ddB BARS: %d\r\n”, rssi, bars);.
Thank you.
I’m getting the following errors:
signalstrength.ino:69:29: error: ‘system_display_bars’ was not declared in this scope
system_display_bars(bars);
signalstrength.ino:66:9: warning: unused variable ‘strength’ [-Wunused-variable]
int strength = map(rssi, -131, -51, 0, 5); // was RSSI
// Manually added, not in Library
#include "Particle.h"
// int rssi = 0;
// int bars = 0;
/* signal strength (u-Blox Sara U2 and G3 modules)
* 0: < -105 dBm
* 1: < -93 dBm
* 2: < -81 dBm
* 3: < -69 dBm
* 4: < - 57 dBm
* 5: >= -57 dBm
system_prepare_display_bars();
int rssi = 0;
int bars = 0;
rssi = WiFi.RSSI();
rssi = sig.rssi;
#endif
if (rssi < 0)
if (rssi >= -57) bars = 5;
else if (rssi > -68) bars = 4;
else if (rssi > -80) bars = 3;
else if (rssi > -92) bars = 2;
else if (rssi > -104) bars = 1;
DEBUG("RSSI: %ddB BARS: %d\r\n", rssi, bars);
