I’d like to run my electron in Semi Automatic mode for testing purposes. No need to waste the data
When I upload the following code through the DFU, my electron breathes a blue/red light and I do not see any output on the serial monitor. I was wondering if anyone had any suggestions. The code works with my Photon.
#include <vector>
#define DEBUG
// Variables:
std::vector<String> Output;
FuelGauge fuel;
// Address of I2C Pressure Transducer
int I2C_ADDRESS2 = 72; // Address 0x48
long sleepTime = 900; //15 minutes
SYSTEM_MODE(SEMI_AUTOMATIC); // for photon/electron right now
void setup(){
Wire.begin(); // join i2c bus (address optional for master)
#ifdef DEBUG
Serial.begin(9600); // start serial for output
#endif
//WiFi.off();
char batt[7];
delay(5000);
Serial.println("TEST");
if (collectData(I2C_ADDRESS2)){
float2string(fuel.getSoC(),batt,3);
Output.push_back(batt);
Particle.publish("RG", Output[0] + "," + Output[1] + "," + Output[2]);
Output.clear();
//sleep
delay(500);
@peekay123 The firmware on my Electron is 0.5.0 and in the Build tab of the dashboard it says it’s building with that same firmware. However, I’m uploading the code through the DFU utility. Do you know if the DFU utility will use 0.5.1 or the 0.5.0 which I have set in the cloud? Please let me know.
@knoose, if you have the Electron connected locally via USB and you use particle update, it will update the Electron with the latest released system firmware which is presently 0.5.1. Make sure to then recompile your own code to this version as well.
@peekay123 Based on your reply, I’m assuming that the Particle CLI uses the most up to date version of the firmware and not the one specified in the Build section of the dashboard? Also, thank you for all your help!
Edit:
After upgrading it’s still breathing Blue/Red. I even changed the code to only contain:
@peekay123 When you enter the following into the command line:
particle update
It does not upgrade to the latest firmware. It downgraded it to 0.4.8, which is what was causing my issues. I manually updated to 0.5.1 and then it worked fine. Thank you for your help.
