My particle always directly going to Listening Mode when trying to connect to the Particle Cloud without blinking green first. Of course a SIM-Card is installed. I also tried to remove the SIM and insert it again with the same result.
I was on 0.5.3 and tried to update to the current Firmware 0.6.2. It states that it was correct but if I try the following in Listening Mode:
$ particle identify
Your device id is 40005e000351353337353037
Unable to determine system firmware version
and
$ particle serial identify
So not sure how to proceed here as it is always entering listening mode even with Tinker App.
$ particle update
> Your device is ready for a system update.
> This process should take about 30 seconds. Here goes!
! System firmware update successfully completed!
> Your device should now restart automatically.
Not possible. So I hold down both buttons and release the reset button. No if it blinks magenta I release the mode button but immediately it jumps back into my application code and does not breathing magenta.
