I wrote a simple app about a month ago, which prints out some serial data.
However, when I compile the exact same code today and flash the Electron, it gets stuck in Listening Mode after a few seconds.
When I upload the compiled .bin from a month ago (I kept a backup) it works just fine.
Inserting a SIM card and removing the
SYSTEM_MODE(SEMI_AUTOMATIC);
doesn’t solve the problem.
Is there anything I am missing, or was something changed in the particle offline IDE I missed?
Thank you!
edit: I just tried the same thing with the blink_LED sample. compiling with the online IDE and downloading the firmware .bin works just fine, but doing the same thing with the Particle DEV results in the electron going straight into Listening mode.
And add some error into your code, to make sure Dev actually building that project you are working on.
If it still builds you’re working on the wrong project.
running the latest system firmware.
I just removed and re-added the electron from my devices and it works now? I have no idea why, I didn’t change a thing except removing and re-adding. Thanks for you help !!
