Has anyone ever tried using the EasyVR for speech recognition with an Electron? It appears as though it should work although I am not sure how to go about it!
Here is a link to the downloads page which has all the information. http://www.veear.eu/downloads/
Any help or ideas is appreciated.
@peekay123 Thanks for your reply. The document says “The EasyVR 3 module can be used with any host with an UART
interface powered at 3.3V – 5V”. Not being an experienced programmer and not able to find any examples. I need to understand how to write the serial commands required to communicate with this module.
Since as you point out, there is an Arduino library, what would have to be done to make this library work with the Electron, if anything?
LOL, I didnt mean to imply that I know what I am talking about!. Just investigating the possibility. I would like to be able to control my project locally with voice recognition. The cloud will serve to send sensor data and control via an app.
@jackpot, Github is down right now (DDOS attack) so I can’t look at the Arduino code. The Electron has several serial ports you can use. Once I look at the code, I’ll let you know what I think.
@jackpot That is a really cool Voice Recognition module that I never knew existed. I have seen the text to voice chips but not the voice recognition units. I’ll have to order one up if Paul get’s the Arduino code ported over.
IBM Bluemix has IBM Watson Speech To Text & Text to Speech service which is very accurate, but it does require you to upload the audio file before it can be processed which would not be very good data wise on the Electron.
Just throwing this in here, since it’s one of the options I’ve been considering: https://www.kickstarter.com/projects/seeed/respeaker-an-open-modular-voice-interface-to-hack
It offers both online and offline recognition, which is really nice. Then again, if I haven’t got an internet connection at home, there’s little use for the recognition since the receiving devices won’t be able to connect either With that in mind, I’m also considering the Amazon devices, since you can (apparantly) create custom skills. They could all still work in tandem with the Particle devices using their respective APIs
@Moors7, I will take a look at your suggestion. Thank you. I believe you can create custom speaker independent commands with the included software for the EasyVR too.
@peekay123, no hurry here. I am spending my time learning how to program and use the device for now. Just updating you on my progress. Thanks for the update and your time.
@jackpot, looking at the code more closesly, I REALLY don’t like the way they have handled the serial devices in their library. They put hard #defines in function definitions and are really poorly designed IMO. I will need to clean things up to get the Particle Serial and Serial1 objects to work with the library. Argh!
