I’ve ported the DogLcd Library for the DOGM Character LCDs made by Electronic Assembly so that they can be used with hardware or software SPI on the Particle Core. The code is available at https://github.com/dfreymann/do_DogLcd.
I’ve tested it using Particle Dev with a DOGM162W-A display (black on white, 16x2 lines, no backlight) connected to a Spark Core, and also tested it in Arduino with the display connected to an Uno. In both cases the basic functionality seems to be working fine.
Usage is similar to the LiquidCrystal library. The author of the Arduino code this library is based on has a nice DogLCD page that provides information about the display.
Here’s the helloWorld -
do_DogLCD library - Hello World
Particle Core port
Version 0.1.8
This exercises a number of the features of the display.
The function at the end can be called to test the full
range of Gain/Contrast settings for the display (note
that it will be 'blank' or 'black' for much of the test)
#include "do_DogLcd.h"
#if defined(SPARK)
#include <application.h>
#elif defined(ARDUINO) && ARDUINO >= 100
#include "Arduino.h"
#include <SPI.h>
#include <WProgram.h>
#include <SPI.h>
#endif
// Initialize the library with the numbers of the interface pins
#if defined (ARDUINO)
// ARDUINO MOSI, SCK, CSB, RS, RESET, BACKLIGHT
// DogLcdhw lcd(11, 13, 10, 9, 4, -1); // ARDUINO test configuration
// Use 0, 0 for MOSI and SCK to initialize hardware SPI
DogLcdhw lcd(0, 0, 10, 9, 4, -1); // ARDUINO test configuration
#elif defined (SPARK)
// SPARK MOSI, SCK, CSB, RS, RESET, BACKLIGHT
// DogLcdhw lcd(15, 13, 12, 11, 10, -1); // SPARK test configuration
DogLcdhw lcd(0, 0, 12, 11, 10, -1); // SPARK test configuration
#endif
//from dogm163 library
byte arrow_down[] = {0x04, 0x04, 0x04, 0x04, 0x15, 0x0E, 0X04, 0X00};
// set up the LCD type and the contrast setting for the display
// Good input values for contrast and gain are 40 and 2 (5V system).
// When running at 3V3 what you see on the display is very sensitive
// to the settings! too low - nothing, too high - black boxes.
// Good input values then are 50 and 3 (3V3 system).
// Enter -1 for contrast/gain to set defaults.
lcd.begin(DOG_LCDhw_M162, DOG_LCDhw_VCC_5V, -1, -1); // ARDUINO test configuration
lcd.begin(DOG_LCDhw_M162, DOG_LCDhw_VCC_3V3, -1, -1); // SPARK test configuration
#endif
// Print a message to the LCD.
lcd.print("hello, spark!");
// note - the overloaded lcd.write() statement reports an error
// "call of overloaded 'write(int, int)' is ambiguous" if this is '0'. however,
// if the value is cast as (byte) in lcd.write(), it will work
// - see http://forum.arduino.cc/index.php?topic=174883.msg1299547#msg1299547
lcd.createChar(0, arrow_down);
// set the cursor to column 0, line 1
// (note: line 1 is the second row, since counting begins with 0):
lcd.setCursor(0, 1);
// print the number of seconds since reset:
lcd.print(millis()/1000);
delay(2000);
// play with contrast - by hand - if too low
// for the gain, you'll see nothing
// lcd.setContrast(50);
lcd.clear();
lcd.setCursor(0,1);
lcd.print("changed contrast?");
delay(2000);
lcd.clear();
lcd.setCursor(0,0);
lcd.print("no blinking");
lcd.noBlink();
delay(2000);
// note that we don't have access to the contrast
// or gain used in the begin() statement. reset()
// gets them for us, however.
lcd.reset();
lcd.setCursor(0,1);
lcd.print("no cursor");
lcd.noCursor();
delay(2000);
lcd.clear();
lcd.blink();
lcd.setCursor(0,0);
lcd.print("ELECTRONIC");
lcd.setCursor(8,1);
lcd.print("ASSEMBLY");
delay(3000);
lcd.clear();
lcd.setCursor(0,0);
lcd.print("My new char?");
lcd.setCursor(1,1);
lcd.ascii(0);
lcd.setCursor(3,1);
lcd.write((byte)0);
lcd.setCursor(5,1);
lcd.write("A");
delay(1000);
lcd.scrollDisplayRight();
delay(1000);
lcd.scrollDisplayLeft();
delay(2000);
lcd.reset();
lcd.print("spark, again!");
delay(1000);
// comment out if you don't want to run through this
//a_little_function_to_check_gain_contrast();
void a_little_function_to_check_gain_contrast() {
// cycles through the full range of gain and contrast
// (omitting gain = 0 and 7, which are unusable) in order to
// demonstrate relationship between contrast and gain
lcd.setCursor(0,0);
lcd.print("gain/contrast");
lcd.setCursor(0,1);
lcd.print("takes time");
delay(2000);
lcd.clear();
for (int i=1; i<7; i++){
lcd.setGain(i);
lcd.setCursor(0,0);
lcd.print("Gain");
lcd.setCursor(6,0);
lcd.print(i);
for (int j=1; j<63; j++){
lcd.setContrast(j);
lcd.setCursor(0,1);
lcd.print("Contr");
lcd.setCursor(8,1);
lcd.print(j);
delay(100);
lcd.clear();
lcd.reset();
