The File system application note includes more than you ever wanted to know about the flash file system.
BLE (Bluetooth LE)
- Firmware API docs updates for 3.1 including LESC encrypted pairing and PHY coded (long range) support
- BLE tutorial updated with flash code from docs
- Web-based BLE serial debug monitor for Chrome
- RSSI Meter example
- LESC just-works encrypted pairing example
Other Updates
- Add mechanical drawing to Tracker SoM datasheet
- Add note about events arriving out-of-order
- Boron and Argon datasheets list wrong number of SPI ports
- Wi-Fi passwords are limited to 64 characters
