On Particle Photon in the "Pins" section DAC is described as:
12-bit Digital-to-Analog (D/A) output (0-4095), and also a digital GPIO. DAC is used as DAC1 in software, and A5 is a second DAC output used as DAC2 in software.
But the adjacent graphic depicts DAC2 on A3, not on A5. Is this a documentation bug or am I misreading it? I'm just trying to help out.
Not sure where you found that since the latest is:
http://docs.particle.io/photon/photon-datasheet/
We've found a number of errors in the Photon Datasheet, so we have removed it until it's completely fixed. If you have technical questions about the Photon, please email hello@particle.io or ask on the community at http://community.particle.io. Thank you for your patience!
@kennethlimcp You can literally go to http://docs.particle.io/photon/#pins and search for the phrase "12-bit Digital-to-Analog (D/A) output (0-4095), and also a digital GPIO. DAC is used as DAC1 in software, and A5 is a second DAC output used as DAC2 in software." and compare that paragraph to the pinout graphic on the right hand sidebar right next to it.
It’s a caching issue and as shown above, they are stuff to be corrected before the information is released back to public
OK, whatever. So DAC2 is really on A3, never mind what the narrative description says. FWIW I just cleared my browser cache and the narrative still reads A5. I’m not trying to be difficult or anything, really just trying to help the particle team identify and correct documentation issues. Sounds like the sentiment is that’s not valuable at this time.
