Photon documentation error on DAC?
I was reading the Photon documentation and when I looked at the DAC in closer detail I found something that didn’t agree.
It is on this page:
http://docs.particle.io/photon/photon-datasheet/
The issue is the second DAC. One says pin A5, the other pin A3.
It’s definitely a documentation error - A3 is correct. Thanks for pointing this out! :+1:
