Going through the E402KIT tutorial and, just flashed it with the sample program to talk to a DHT11 sensor, but using CONN2 it’s only reporting back: “Failed to read from DHT sensor”
have same issue with E310KIT (the 2G/3G version), that sensor does not work. Just order a new one from digikey and will test it out next week. I did not test sensor on Arduino.
I also tried the standalone code that reads and send serial. Nothing.
