Hi recently got the E SERIES EVAL KIT and was following the instructions on how to test using this
https://docs.particle.io/tutorials/hardware-projects/e-series-eval-kit/
everything works fine but when i flash my code on the device i get the error
Failed to read from DHT sensor
seems the device is not able to read from the sense
can anyone guide on what to look for in order to fix this
