I have a DHT11 sensor on a 3-pin breakout board with a 10k resistor on the board between the Vcc and signal lines. This should be a very straight forward sensor with VCC connected to the Photon 2 3.3 pin; ground to ground and the signal wire is connected to D4.
Using the following code
#include <Adafruit_DHT_Particle.h>
#define DHTPIN D4 // Define the pin connected to the DHT sensor
#define DHTTYPE DHT11 // Define the type of DHT sensor
DHT DHT(DHTPIN, DHTTYPE); // Initialize the DHT sensor
Serial.begin(9600); // Start serial communication at a baud rate of 9600
DHT.begin(); // Initialize the DHT sensor
// Read humidity and temperature values
float humidity = DHT.getHumidity();
float temperature = DHT.getTempCelcius();
// Check if any reads failed and exit early (to try again).
if (isnan(humidity) || isnan(temperature)) {
Serial.println("Failed to read from DHT sensor!");
} else {
// Print the results to the serial monitor
Serial.print("Humidity: ");
Serial.print(humidity);
Serial.print("%, Temp: ");
Serial.print(temperature);
Serial.println(" Celsius");
delay(10000); // Wait for 30 seconds before reading again
I get the following results.
Humidity: 0.00%, Temp: 0.00 Celsius
Any ideas on why I can't pull simple temperature and humidity readings with the Photon 2 and this sensor? I've had the same results with another sensor, both are known good. I've also had the same results when trying a DHT22 and similar code.
I also loaded the sample code that comes with the library and get these values...
Humid: 160.00% - Temp: 128.00C 262.40F 401.15K - DewP: 143.98C - HeatI: 3629.76C
Thu Jan 11 02:28:39 2024
Humid: 176.00% - Temp: 128.00C 262.40F 401.15K - DewP: 147.39C - HeatI: 4043.13C
Thu Jan 11 02:28:50 2024
Humid: 0.00% - Temp: 0.00C 32.00F 273.15K - DewP: nanC - HeatI: -8.78C
Thu Jan 11 02:29:00 2024
Thu Jan 11 02:29:10 2024
Humid: 128.00% - Temp: 0.00C 32.00F 273.15K - DewP: 3.45C - HeatI: 21.45*C
Thu Jan 11 02:29:20 2024
