Dfu-util: command not found on MBP, Mac OS 10.9.4 [Solved]
Hello Guys,
I was trying to install dfu-util on my MBP so that I can update the my spark core with the latest firmware but I had problems on that:
According to instructions on http://dfu-util.gnumonks.org/, it seems macports is the only thing I need. So I went to https://www.macports.org/install.php, following the instructions to install:
  1. install xcode
  2. xcode-select --install
  3. download MacPorts-2.3.1-10.9-Mavericks.pkg and install
  4. checked $ port version, looks good.
but when I’m trying to use the dfu-util, I had the following problem.
$ spark flash --usb cc3000
Apparently I didn’t find a DFU device? util said
Error writing firmware… no dfu device found.
$ sudo dfu-util -l
Password:
sudo: dfu-util: command not found
Any suggestions on this?
Yan
Hi @FlyingYanz,
I think you missed the part where you installed dfu-util, something like:
sudo port install dfu-util
sudo port install libusb
David
Thanks David!
This solved the problem
