Device stuck in limbo: Cannot move protected device between products
How can I add my protected device to my product? I'm upgrading one of our devices hardware and adding it to a new product. I removed the device from the old product just fine, but adding it seems not to work in the console or the web UI. I also can't remove device protection.
particle product device remove <old_product> <device_id>
--> success
particle product device add <new_product> <device_id>        1 ↵
Skipped Protected IDs:
  <device_id>
particle device-protection disable -d <device_id>        1 ↵
Failed to disable Device Protection: Device is not found
The device shows up in our devices list just fine:
particle list | grep device-name        1 ↵
device-name [<device_id>] (Asset Tracker / Monitor One) is online
I was able to fix the issue by adding the device back into the original product, marking it as a development device, then adding it to the destination product.
Hi @coala this is expected. behavior. If you do need to move protected devices into products in the future, make sure to mark as development before moving.
