Via
- Ctrl+Shift+P Particle: Configure Workspace for Device, or
- by manually editing the
[project].code-workspace
file like this
"settings": {
"particle.targetDevice": "yourDeviceName",
"particle.firmwareVersion": "0.8.0-rc.27", # one of the allowed toolchains (not all versions are supported)
"particle.targetPlatform": "yourPlatform" # one of [ photon | p1 | electron | argon | boron | xenon ]
Debugging isn't yet officially supported (but planned), but you can build debug firmware via
Ctrl+Shift+B Particle: Compile application for debug (local)
And to setup debugging you could follow this
