Custom Webhook Thingsboard
I install the on-premise community edition Thingboard, I think the integration with Particle will be easy but…
I configure a device in thingboards “Pluviometro”, and try to configure a custom webhook in Particle.
My event is rain, but I read the webhook guide in Particles Docs and are very confuse for me.I’m far away from json’s…:(( .
If somebody give me some help it will be awesome.
curl -v -X POST -d “{“Pluviometro”: 32}” http://things.hackuy.com:8080/api/v1/$TOKEN_THINGSBOARD/telemetry --header “Content-Type:application/json”
thanks in advance
Sorry didn’t see this post so is a duplicate to the one I created from your Private message.
Pablo, firstly your Quotes are wrong. Try using Double quotes for the curl parameter but single quotes in the JSON parameter.
Secondly, The TOKEN_THINGSBOARD should be the device token, so In thingsboard click on Manage Credentials and use the TB generate token. Then you should have a telemetry update.
E.G. curl -v -X POST -d "{'temperature': 25}" https://www.s2j.io:8080/api/v1/1a2b3c4d5e6f7g8h9i0j/telemetry --header "Content-Type:application/json"
Responding to a Private Message from Pablo Rattin
Hi Jhonny, I want to add a particle to thingsboards via webhook?
I read your post in the comunity, I’m total lost,I’m far far far away of json’s etc.
curl -v -X POST -d “{“temperature”: 25}” xxxxx.com --header “Content-Type:application/json”
I test the device over thingboard with curl.
Any help will be very appreciated
Thank you for your fast respones, definetl you put me in the way.
I read the documents in particle, and look for rickass tutorials,
Thank you for your advice, Irealy appreciate!!!
Friendly }regards from Uruguay
“event”: “rain”,
“url”: “http://things.hackuy.com:8080/api/v1"Put the Token here : ))”/telemetry",
“requestType”: “POST”,
“rejectUnauthorized”: false,
“headers”: {
“Content-Type”: “text/json”
“json”: {
“Pluviometro”: “{{PARTICLE_EVENT_VALUE}}”
“noDefaults”: true
Just in case someone stumbles across this, I have been trying to do the same, get data from a mesh device into thingsboard. It took a bit of fiddling to get the format right, but for me it turned out to be far simpler than I expected. It is a very cut down version of the above.
I produced the JSON in my code:
   // Publish as events
    sprintf(jsonOut, "{'battery': %0.2f;'soilMoisture': %d;'humidity': %0.2f; 'temperature': %0.2f; 'pressure': %0.2f}",
      batVolts, s, humid, temp, pres);
    Particle.publish("Soil1JSON", jsonOut, PRIVATE);
In thingsboard under device management, create your device and copy the token.
Create a webhook with the URL:
http://yourserver:yourPort/api/v1/AccessToken/telemetry
pasting in your server name, port and access token
Set the type to POST and format JSON. For the JSON just use:
"{{{PARTICLE_EVENT_VALUE}}}"
Thingsboard then just picks up on the field names in your JSON, so to add a new data stream, just add an extra section to your JSON.
Hi Dave,
I am close but this hasn’t quite worked for me and I wonder if it’s because the data is being sent with a " before the {.
Here is the output of my webhook:
“name”: “osVoltage”,
“data”: “{‘temp’: 14.20, ‘voltage’: 3.64}”,
“ttl”: 60,
“published_at”: “2020-05-21T13:32:21.120Z”,
“coreid”: “e00fce68b0560d86910c7c4d”
All of this data comes into my things board however the field data is populated with the string {‘temp’: 14.20, ‘voltage’: 3.64} and not the JSON format where I would expect to have extra fields that I can use in my dashboard.
Were you able to work around that? Any ideas there?
Thanks.
Ok, I fixed by doing as you said, all you need in the JSON for the webhook is: “{{{PARTICLE_EVENT_VALUE}}}”
