Photon with thingsboard integration
I am trying to integrate particle photon with thingsboard IoT platform.
I can easily push data to thingsboard platform and read it there but I am struggling with control of particle.
I did one baby step which is trying to control my computer.
To do so I have to send message to thingsboard:
curl -v -X GET https://cloud.thingsboard.io/api/v1/ZD4SrkUvct5tqGe9cTnV/rpc/
and in response I receive message:
{“id”:44,“method”:“setValue”,“params”:“54.00”}
Now i created Webhook with GET request but i cannot get response.
I am calling in loop code this command:
Particle.publish(“SmartBlanket3_TB_GET”, PRIVATE);
but cannot reach answer with that commands:
  // Subscribe to the integration response event
  Particle.subscribe("hook-response/SmartBlanket3_TB_GET", myHandler, MY_DEVICES);
void myHandler(const char *event, const char *data) {
  // Handle the integration response
blkt4ActTemp = random(1,5);
At the moment I tried to round some number in handler but it doesn’t work because it doesn’t change. It seems that I have to do something wrong.
How can I run properly this handler to round number?
What is the easiest way to get this string {“id”:44,“method”:“setValue”,“params”:“54.00”} in my particle?
Would be good to see how you are actually doing that in your loop().
Also showing how your webhook looks and checking Particle Console | Build your connected product would be helpful.
Particle Console | Build your connected product may also provide some info about the call history of your webhook.
To understand your properly we'd need more info.
How are you setting up the RPC in thingsboard? what are the related rules?
This topic was automatically closed 60 days after the last reply. New replies are no longer allowed.
