Webhooks/Integration Help
Trying to create a custom webhook in the particle integration. I am a bit confused, tried multiple variations without any luck.
Getting error 401:
Double check that you configured your integration correctly. You may need to re-create it if this failure persists.
Here is my Postman code that is working well:
curl --location 'https://api.smartthings.com/v1/devices/qweu222222/commands'
--header 'Content-Type: text/plain'
--header 'Authorization: Bearer exxxxxxxx448b'
--data '{
"commands": [
"component": "main",
"capability": "switch",
"command": "on",
"arguments":
How do I input this into the webhook builder. (Having problem with the data section, )
thanks
It should probably look something like this. Main thing is to make it POST and JSON.
I wasn't quite sure what the box for arguments was supposed to be, but the parameter should be a string.
The headers look like this:
thanks it works
