Connecting to open wifi network
I was just starting to type the same thing, @wgbartley - thank you! (The Starbucks in Menlo Park this past weekend was definitely sign-in contingent).
That's a problem I keep having. I feel good when I can beat @bko or @peekay123 to the punch. :smile:
Guys,
That’s it! It does require me to click a button accepting terms and conditions.
Thanks for the help!
@wgbartley, curse you and your speedy responses! :wink:
@Dup,
the Wifi module is not able to handle such special cases of Wifi Environment so you might have to see alternatives :wink:
do I need to do anything or does it just remember the last 7 connected on its own?
It just automatically remembers up to 7. You don’t have to do a thing!
If you actually try to set an 8th profile, I’ve heard tell of weird behavior, so better to clear profiles by holding the MODE button for 10 seconds if you build up that many.
