Connecting Spark Core to Wifi with no passcode
Hey, I’m using the spark core in a school project, however the spark core app does not want to allow the core to connect, because the wifi does not have a password associated with it. The spark core app looks like it should connect, however when I try it the core continues blinking blue. Is this a software issue, is it just due to some blocks on the wifi, is there anything else that i could do to connect it?
I’m not sure if there is a way in the app, but there is an (relatively - for Windows) easy way via the USB serial connection.
When your Core is in Listening Mode it opens a serial port to which you can connect and send w to which the Core will respond with asking you for SSID, protection scheme (open in your case) and the passphrase (empty for you).
or
You can use CLI
or
You could write a one-time sketch that uses WiFi.setCredentials() to infuse the data of your school WiFi
or
