Is Boron allows to publish data directly to Azure or any other cloud?
This needs to happen without any Webhooks via Particle cloud.
@prasannarode, the Boron does not support direct encrypted transactions so it cannot publish data directly to Azure or any other cloud without webhooks.
thank you peekay for quick reply. I will use the webhook provided by Particle.
Its easy to configure using Console.
Depending on how you plan to connect to Azure, you could use a library like TlsTcpClient or MQTT-TLS to send messages directly to the cloud. I do this with AWS IoT.
