Good day,
Facing the loss of 3G in my area using my present Electron 3G, can I just confirm that the LTE version of the E404Kit would be the proper unit to migrate to?
Thanks very much.
Good day,
Thanks very much.
Hi Shorpal- You are correct the E404x is the proper unit to migrate to.
What area are you in? The United States, Canada, and Mexico?
The E404KIT is an E Series module evaluation board. While software compatible with the Electron, there are two issues:
If you can find one (used, or new, sitting on a shelf at some distributor), and you are in the United States, Canada, or Mexico, the ELC402EA is what you probably want. It’s the same form-factor as the E260 Electron but is LTE Cat M1.
Thanks very much.
I’m in the NE USA and I was nervous about the E404KIT because its page on Particle.io mentions it is soon to be terminated due to lack of parts. That’s fine but I just wanted to make sure it will continue to function. The larger form factor is OK for my use.
Thanks again!
