Condition for flashing cyan
Does someone know the boolean condition when the Core is flashing cyan (connected to wifi but not connected to the cloud yet)? It’s close to WiFi.ready() && !Spark.connected() but WiFi.ready() goes true for a short time then goes false.
I need this for agreeing to a captive portal. The HTTP code to accept the portal terms is working but I need to know when to run it. I want to do this when the core is flashing cyan for 5 seconds.
Thanks.
It may be a combination of these flags… or might be more low level…
https://github.com/spark/firmware/blob/develop/system/system-flags.md
You could also try SYSTEM_MODE(SEMI_AUTOMATIC); and see if that helps make the connection easier:
http://docs.particle.io/photon/firmware/#system-modes-semi-automatic-mode
