My core has been running fine for about a year. I don’t believe the code nor anything on the hardware side has been changed in many months but it’s started flashing cyan out of the blue lately. Technically there is a brief flash of red in between long periods of flashing cyan. It happened for the first time 2 days ago and the second time just now after running fine about 24 hours. Each time time the only way to resolve the issue is to press the reset button.
I’ve been using your code for about a month with no issues until today. My core went offline last night and has failed to reconnect over the past 8 hours. Interestingly this time it’s breathing blue and then white on the RGB LED. It seems steady, it’ll jump to solid blue and slowly fade out and then back in and then jump to white and fade out and back in before the cycle repeats. The code on the core is still running as I have several LEDs to show me what it’s doing; so it appears the connection to the cloud is the only thing impacted.
After hitting the reset button it was back online within a few seconds.
@Fragma , @kennethlimcp - I’ve had a similar experience with the core (losing cloud connection) whereas the photon seems to reconnect to cloud better than the core with the newer firmware
