Changing the Name on the Photon [Resolved]
The Photon didn’t like when I left out the “_” in the name, looks like my Photon re-assigned a new name.
Is there an easy way to change the name in the setup ?
What name, what ‘_’, and what setup?
You can edit the device name in the devices tab in the Web IDE. You can also most likely do the same using the CLI. Give the help command a try to find out how. Alternatively? have a look in the docs.
Thanks ! Found it in the Tinker App, Inspector, More Actions, Rename Device.
Thanks @Moors7 for the help!
