Can't compile due to Makefile
Hi all,
I have suddenly gotten a error when I try to compile my program:
:::: COMPILING APPLICATION & DEVICE OS
make[1]: MyUserName.particle\toolchains\buildscripts\1.15.0\Makefile: No such file or directory
make[1]: *** No rule to make target 'MyUserName.particle\toolchains\buildscripts\1.15.0\Makefile'. Stop.
make: *** [C:\Users\MyUserName.particle\toolchains\buildscripts\1.15.0\Makefile:95: compile-all] Error 2
  • The terminal process "C:\Users\MyUserName.particle\toolchains\buildtools\1.1.1\bin\bash.exe '-c', 'make -f 'C:\Users\MyUserName.particle\toolchains\buildscripts\1.15.0\Makefile' compile-all -s'" terminated with exit code: 2.
  • Press any key to close the terminal.
(I have replaced my name with 'MyUserName')
I'm new to this device but I have gotten a few program to run without any error. Now my new program and the previous ones won't compile. Does anyone have a way around this error and perhaps get the compiler to create the Makefiler again?
I'm using Visual Studio Code with the Workbench extension. I have tried to uninstall both and reinstall them.
I'm running an Argon which is connected via USB and the LED is "breating cyan" which should indicate that it is running & ready for compile + flash.
I would first try Particle: Configure Project for Device and reselect your Device and Device OS version.
If that doesn't work, try Particle: Install Local Compiler Toolchain.
You could also try cloud compiling instead of local compiling using Particle: Cloud flash which is generally much easier and faster, especially with the Argon.
Thank you for your reply !
I tried Particle: Configure Project for Device and Particle: Install Local Compiler Toolchain and both fully processed both the problem remains - it won't compile! It gives the same error code as before.
I tried Cloud compile which is able to compile & flash the Argon but I can't see any messages printed in the console with the Serial.printf("Hello World") command. But I have a test project where I send data to a Thinksspeak project and this project does recieve data from the Argon so it must work in some sense.
I tried to read some of the info from:
Troubleshooting the Particle Workbench | Troubleshooting | Particle
And from this link
The "arch" does indicate an x86 on my end and that is not support as I understand it. But how to I change that to something that works with the Argon?
Was this issue ever resolved? I am having the same issue. The only difference is that I working with the BSOM instead of Argon. But the symptoms are the same and the suggested fix posted by rickkas7 doesn't work.
Any updates on how this has been fixed would be appreciated.
Did you follow the steps to repair your environment above? There's a longer list of steps in the docs.
If that doesn't fix it, scroll to the end of that page and follow the instructions to get an environment report.
Can you send that link again? The link that was in your last post was to a New York Times article.
Oops. I corrected the link.
Thanks for correcting the link. The instructions in the linked website directs me to first run a basic workbench functionality test, wherein I create a new blank project and perform a local compile of a blank firmware. It is during that local compile that I receive the errors referenced previously, which are:
  • Executing task: make -f 'C:\Users\MyUserName.particle\toolchains\buildscripts\1.15.0\Makefile' compile-all
C:\Users\MyUserName.particle\toolchains\buildscripts\1.15.0\Makefile:156: target '-' given more than once in the same rule
make -f Name.particle\toolchains\buildscripts\1.15.0\Makefile compile-all-steps
make[1]: Entering directory '/cygdrive/c/Users/MyUserName/Company Name/Docs - Documents/Clients/Other Company/Code/Particle/SetupTest'
make[1]: Name.particle\toolchains\buildscripts\1.15.0\Makefile: No such file or directory
make[1]: *** No rule to make target 'Name.particle\toolchains\buildscripts\1.15.0\Makefile'. Stop.
make[1]: Leaving directory '/cygdrive/c/Users/MyUserName/Company Name/Docs - Documents/Clients/Other Company/Code/Particle/SetupTest'
  • The terminal process "C:\Users\MyUserName.particle\toolchains\buildtools\1.1.1\bin\bash.exe '-c', 'make -f 'C:\Users\MyUserName.particle\toolchains\buildscripts\1.15.0\Makefile' compile-all'" terminated with exit code: 2.
The above is the same error in the initial post of this thread.
I checked all the items in the Environment Report, as specified in the link given. All of the elements appeared exactly as specified.
Which command are you using to invoke the build? From the command palette (and which command) or from the compiler shell?
What version of the Workbench core plug-in?
Does your project pathname contain spaces? This should work in the most recent version when using the Command Palette, but does not work on earlier versions and is tricky to make work from the command prompt.
The problem was spaces in the pathname. I started a new project in a different location, without spaces in the pathname. The problem no longer appeared.
For reference, I invoked the compile command by clicking on "Local compile" in the Particle Workbench tab. I had exactly the same result by clicking on the "Compile Project" button in the upper right toolbar. I am running version 1.16.15 of the Workbench core plug-in.
