Local Compile Stopped Working (Workbench)
I've been working on and compiling a project half the day and now the local compiler has mysteriously stopped working.
I am getting the following error (particular file has changed but is now stuck on globals.cpp)
Executing task: make -f 'C:\Users\vdw.particle\toolchains\buildscripts\1.9.2\Makefile' compile-user -s <
:::: COMPILING APPLICATION
make[3]: *** No rule to make target 'c:\work\11589\src\globals.cpp', needed by '../build/target/user/platform-6-m/11589/src/globals.o'. Stop.
make[2]: *** [../../../build/recurse.mk:12: user] Error 2
make[1]: *** [../build/recurse.mk:12: modules/photon/user-part] Error 2
make: *** [C:\Users\vdw.particle\toolchains\buildscripts\1.9.2\Makefile:54: compile-user] Error 2
The terminal process terminated with exit code: 2
I have opened other projects and they are compiling without error so I don't think it's the makefile. I've also rolled back to commits that I know compiled previously and they don't compile now.
I think there is something wrong with the project setup, but I cannot figure out what.
settings.json
    "extensions.ignoreRecommendations": true,
    "C_Cpp.default.configurationProvider": "particle.particle-vscode-core",
    "files.associations": {
        "*.ino": "cpp",
        "*.tcc": "cpp"
    "particle.firmwareVersion": "1.0.1",
    "cortex-debug.openocdPath": "${command:particle.getDebuggerOpenocdPath}",
    "particle.targetDevice": "11589"
I am also using some Particle Libraries and a file I was working on used one of these libraries (ITEADLIB_Nextion)
project.properties
name=11589
dependencies.clickButton=1.0.9
dependencies.ITEADLIB_Nextion=0.0.16
Have you tried the clean task?
That worked! Thank you!
