Cannot reset Argon
Hi all,
I have tried everything I know to reset my Argon and I always get 13 red flashes when it reboots.
I have downloaded 1.3 firmware from this link: https://github.com/particle-iot/device-os/releases
C:\Particle\Firmware\1.3.1\argon\release
λ particle flash --usb argon-system-part1@1.3.1.bin
Flash success!
λ particle flash --serial argon-bootloader@1.3.1.bin
! PROTIP: Hold the SETUP button on your device until it blinks blue!
? Press ENTER when your device is blinking BLUE
Error writing firmware: No serial port identified
sending file: argon-bootloader@1.3.1.bin
Flash success!
λ
After reboot, short blue flashing, then launch the Particle app from my Android phone, pick the Argon, scan the sticker, pick a Wifi network, enter password, the device always flashes red 13 times.
Any advise? How do I reset this thing completely?
Greg
Try to also replace the application firmware via
particel flash --usb tinker -v
That did not work, still 13 red flashes on reboot.
λ particle flash --usb tinker -v
dfu-util 0.8
ID 2b04:d00c
Claiming USB DFU Interface...
dfuIDLE, continuing
Downloading to address = 0x000d4000, size = 11972
Download [=========================] 100% 11972 bytes
Download done.
File downloaded successfully
Transitioning to dfuMANIFEST state
Invalid DFU suffix signature
Flash success!
λ
Can you put the device in Listening Mode and post the log of particle serial inspect?
Here are the results:
λ particle serial inspect
Platform: 12 - Argon
Modules
Bootloader module #0 - version 401, main location, 49152 bytes max size
Integrity: PASS
Address Range: PASS
Platform: PASS
Dependencies: PASS
System module #1 - version 1321, main location, 671744 bytes max size
Integrity: PASS
Address Range: PASS
Platform: PASS
Dependencies: PASS
User module #1 - version 5, main location, 131072 bytes max size
UUID: 72B73BFAB5C902DBE9EC90A13958C90408C6FA4758B9F9C5CFB5100141C1C58B
Integrity: PASS
Address Range: PASS
Platform: PASS
Dependencies: PASS
System module #1 - version 326
NCP module #0 - version 5, main location, 1536000 bytes max size
Integrity: PASS
Address Range: PASS
Platform: PASS
Dependencies: PASS
Radio stack module #0 - version 169, main location, 192512 bytes max size
Integrity: PASS
Address Range: PASS
Platform: PASS
Dependencies: PASS
Not sure what’s going on, but you can also try updating the NCP (via --serial) and the SoftDevice (via --usb).
Can you also share a video of the RGB LED codes (min. 30sec).
I updated the SoftDevice and have the same errors. Can you explain how to update the NCP?
Here is a link to the video.
I had forgotten to link the NCP binary before - it's there now.
The video has provided some crucial info.
Before I took this
as a panic code red SOS+13 but in the video it looks more like orange which might indicate a keys issue
https://docs.particle.io/tutorials/device-os/led/photon/#red-blink-basic-errors
