Cannot flash Photon from Visual Studio Code
Greetings, all. Problem: After several successful flashes of code from Visual Studio Code to my first two Photons, I bought several more & registered them. But whenever I flash code to the new ones (using the same computer & USB cable), I get this message:
Unable to open USB device: LIBUSB_ERROR_NOT_SUPPORTED
I tried flashing an original Photon & that worked. But when I tried re-flashing it, I got:
:::: PUTTING DEVICE INFO DFU MODE
Request timeout
I was really looking forward to developing applications, so this is incredibly frustrating. Does anyone have any suggestions for flashing these beasts successfully?
USB control commands are only supported four a relatively short time now, so I guess your Photons need a device OS update first.
For that put the device in DFU mode manually and run
particle update
then try again
Thank you - that solved the problem! (Though sometimes I still have to put the Photon into DFU mode manually for some reason, but at least now I know to do that.)
A small suggestion for the Visual Studio Code / Particle interface: Why not add a helpful suggestion to the
“Unable to open USB device: LIBUSB_ERROR_NOT_SUPPORTED”
message, such as your reply to my question? I did Google the problem & didn’t find anything helpful. Reason: I’m (like many people) in a rush project & need to choose a new microcontroller quickly. If I hadn’t received your reply today I would have returned my Photons to Amazon and moved on to another microcontroller family.
Just a thought.
This topic was automatically closed 60 days after the last reply. New replies are no longer allowed.
