Cannot activate Electron
Hello,
I use an Electron with setup/reset buttons instead of mode. I live in Manila and I can't seem to activate. The Electron keeps rapidly blinking white and that's something not listed in the troubleshooting modes guide. I used setup.particle.io to activate the SIM details and paid for it about a week ago. Since I haven't used the Electron in a while I guess it needed a firmware upgrade but it's consistently failing and showing "Aw, something went wrong." without much further details. Have tried factory resetting it before upgrading but it doesn't work either..
https://docs.particle.io/guide/getting-started/modes/electron/#safe-mode
https://docs.particle.io/guide/tools-and-features/firmware-manager/electron/
Also, is it possible to use a local SIM with the Electron?
Thank you!
Isamu
It is possible to use a 3rd party SIM. If you search for 3rd party SIM you’ll find some threads.
You can also look at the Electron reference docs here
https://docs.particle.io/reference/firmware/electron/#setcredentials-
The factory reset procedure outlined in your linked thread refers to the Core not Electron.
For the Electron try Safe Mode instead, that’d be the first thing to try.
Breathing white sounds like you might have had SYSTEM_MODE(MANUAL) set in your currently running code.
Thanks for the reply! It’s rapidly blinking white, not breathing. I have tried putting it in safe mode and flashing by holding down the setup and reset buttons, then letting go of the reset button until magenta comes up --which it does immediately, or I can wait for it to cycle again. It doesn’t stay breathing magenta though and just goes back to rapid white.
I followed this: https://docs.particle.io/guide/getting-started/modes/electron/
I don’t remember ever setting it to SYSTEM_MODE(MANUAL), is there a way to revert this? The firmware upgrade does not work at all and I cannot see my electron from the list of devices.
Verified that the U270 version I have should work with Asia here: Electron + Particle SIM + U260/U270 confusion in AU = unable to activate
Isamu
Have you got CLI installed (including dfu-util)?
If so, you could flash the device via DFU Mode (blinking yellow) back to the original tinker app
particle flash --usb tinker
And if you wish you can update to the newest stable system version
particle update
I'm getting this error:
Microsoft Windows [Version 10.0.10586]
(c) 2015 Microsoft Corporation. All rights reserved.
C:\Users\Isamu>dfu-util -l
dfu-util 0.9
Please report bugs to dfu-util / Tickets
C:\Users\Isamu>particle flash --usb tinker
Found DFU device 2b04:d00a
checking file C:\Users\Isamu\AppData\Roaming\npm\node_modules\particle-cli\binaries\electron_tinker.bin
spawning dfu-util -d 2b04:d00a -a 0 -i 0 -s 0x08080000:leave -D C:\Users\Isamu\AppData\Roaming\npm\node_modules\particle-cli\binaries\electron_tinker.bin
dfu-util 0.9
ID 2b04:d00a
Claiming USB DFU Interface...
dfuIDLE, continuing
Downloading to address = 0x08080000, size = 5776
Download [=========================] 100% 5776 bytes
Download done.
File downloaded successfully
Invalid DFU suffix signature
Cannot open DFU device 2b04:d00a
Error during download get_status
Error writing firmware...Invalid DFU suffix signature
C:\Users\Isamu>particle update
!!! I was unable to detect any devices in DFU mode...
Your device will blink yellow when in DFU mode.
If your device is not blinking yellow, please:
  1. Press and hold both the RESET/RST and MODE/SETUP buttons simultaneously.
  2. Release only the RESET/RST button while continuing to hold the MODE/SETUP button.
  3. Release the MODE/SETUP button once the device begins to blink yellow.
Your device is ready for a system update.
This process should take about 30 seconds. Here goes!
! An error occurred while attempting to update the system firmware of your device:
Please visit our community forums for help with this error:
https://community.particle.io/
C:\Users\Isamu>
You can ignore the invalid suffix error, it’s more a warning than an actual error.
But no idea why the second particle update didn’t work.
Maybe you can try the manual update procedure shown here (the binaries can be downloaded at the end 0.5.2 section)
https://github.com/spark/firmware/releases/latest
