I think there has been a change in the last couple of weeks with the command line build ?
I’m pretty sure I did a build within the last couple of weeks which built fine.
This is code I have been using for a year.
Anyway first thing I get a new error :
Compile failed. Exiting.
firmware.cpp:2:28: fatal error: IntervalTiming.h: No such file or directory
#include "application.h"
compilation terminated.
make[1]: *** [../build/target/user/platform-6firmware.o] Error 1
make: *** [user] Error 2
I think that its complaining about my file paths. They are referenced correctly (relatively) in particle.include
and I just specify the filename only in firmware.ino
I think that no longer works, so I change all the file references in firmware.ino to specify full relative path.
Now I get :
Error loading command /usr/lib/node_modules/particle-cli/commands/SerialCommand.js Error: Module version mismatch. Expected 48, got 46.
Compiling code for p
Including:
/work/food_aversions/spark/indoor-air-quality-dashboard/firmware-oled/firmware.ino
/work/food_aversions/spark/indoor-air-quality-dashboard/libs/smileys.h
/work/food_aversions/spark/indoor-air-quality-dashboard/libs/IntervalTiming/IntervalTiming.cpp
/work/food_aversions/spark/indoor-air-quality-dashboard/libs/IntervalTiming/IntervalTiming.h
/work/food_aversions/spark/indoor-air-quality-dashboard/libs/HttpClient/HttpClient.cpp
/work/food_aversions/spark/indoor-air-quality-dashboard/libs/HttpClient/HttpClient.h
/work/food_aversions/spark/indoor-air-quality-dashboard/libs/ReadingSync/ReadingSync.cpp
/work/food_aversions/spark/indoor-air-quality-dashboard/libs/ReadingSync/ReadingSync.h
/work/food_aversions/spark/indoor-air-quality-dashboard/libs/RgbLedControl/RgbLedControl.cpp
/work/food_aversions/spark/indoor-air-quality-dashboard/libs/RgbLedControl/RgbLedControl.h
/work/food_aversions/spark/indoor-air-quality-dashboard/libs/DHT22/PietteTech_DHT.cpp
/work/food_aversions/spark/indoor-air-quality-dashboard/libs/DHT22/PietteTech_DHT.h
/work/food_aversions/spark/indoor-air-quality-dashboard/libs/SimpleEeprom/SimpleEeprom.cpp
/work/food_aversions/spark/indoor-air-quality-dashboard/libs/SimpleEeprom/SimpleEeprom.h
/work/food_aversions/spark/indoor-air-quality-dashboard/libs/SensorBase/SensorBase.cpp
/work/food_aversions/spark/indoor-air-quality-dashboard/libs/SensorBase/SensorBase.h
/work/food_aversions/spark/indoor-air-quality-dashboard/libs/TGS2602/TGS2602.cpp
/work/food_aversions/spark/indoor-air-quality-dashboard/libs/TGS2602/TGS2602.h
/work/food_aversions/spark/indoor-air-quality-dashboard/libs/Adafruit/Adafruit_SSD1306.cpp
/work/food_aversions/spark/indoor-air-quality-dashboard/libs/Adafruit/Adafruit_SSD1306.h
/work/food_aversions/spark/indoor-air-quality-dashboard/libs/Adafruit/Adafruit_GFX.cpp
/work/food_aversions/spark/indoor-air-quality-dashboard/libs/Adafruit/Adafruit_GFX.h
../../../build/target/user/platform-6/libuser.a(firmware.o): In function `dht_wrapper()':
firmware.cpp:108: undefined reference to `PietteTech_DHT::isrCallback()'
../../../build/target/user/platform-6/libuser.a(firmware.o): In function `calibrate(String)':
firmware.cpp:278: undefined reference to `ReadingSync::startCalibrating(int)'
../../../build/target/user/platform-6/libuser.a(firmware.o): In function `sample(String)':
firmware.cpp:283: undefined reference to `ReadingSync::startUserSampling(int)'
../../../build/target/user/platform-6/libuser.a(firmware.o): In function `set2602Calib(String)':
firmware.cpp:291: undefined reference to `SimpleEeprom::writeFloat(float, int)'
../../../build/target/user/platform-6/libuser.a(firmware.o): In function `read_dht22()':
firmware.cpp:249: undefined reference to `PietteTech_DHT::acquire()'
firmware.cpp:251: undefined reference to `PietteTech_DHT::acquiring()'
firmware.cpp:258: undefined reference to `PietteTech_DHT::getHumidity()'
firmware.cpp:259: undefined reference to `PietteTech_DHT::getCelsius()'
../../../build/target/user/platform-6/libuser.a(firmware.o): In function `setup':
firmware.cpp:78: undefined reference to `SimpleEeprom::readFloat(int)'
firmware.cpp:86: undefined reference to `Adafruit_SSD1306::begin(unsigned char, unsigned char)'
firmware.cpp:87: undefined reference to `Adafruit_SSD1306::display()'
../../../build/target/user/platform-6/libuser.a(firmware.o): In function `loop':
firmware.cpp:116: undefined reference to `ReadingSync::getStage(int)'
firmware.cpp:122: undefined reference to `SensorBase::startSampling(unsigned long)'
firmware.cpp:124: undefined reference to `SensorBase::isSamplingComplete()'
firmware.cpp:124: undefined reference to `SensorBase::isTimeToRead(unsigned long)'
firmware.cpp:127: undefined reference to `SensorBase::isSamplingComplete()'
firmware.cpp:129: undefined reference to `TGS2602::getSewerGasPercentage(float)'
firmware.cpp:134: undefined reference to `IntervalTiming::startIntervalTime(unsigned long)'
firmware.cpp:135: undefined reference to `Adafruit_SSD1306::clearDisplay()'
firmware.cpp:136: undefined reference to `Adafruit_GFX::setTextColor(unsigned short)'
firmware.cpp:138: undefined reference to `Adafruit_GFX::setTextSize(unsigned char)'
firmware.cpp:139: undefined reference to `Adafruit_GFX::setCursor(short, short)'
firmware.cpp:144: undefined reference to `Adafruit_GFX::setTextSize(unsigned char)'
firmware.cpp:145: undefined reference to `Adafruit_GFX::setCursor(short, short)'
firmware.cpp:150: undefined reference to `Adafruit_GFX::setTextSize(unsigned char)'
firmware.cpp:151: undefined reference to `Adafruit_GFX::setCursor(short, short)'
firmware.cpp:159: undefined reference to `Adafruit_GFX::drawBitmap(short, short, unsigned char const*, short, short, unsigned short)'
firmware.cpp:161: undefined reference to `Adafruit_SSD1306::display()'
firmware.cpp:163: undefined reference to `IntervalTiming::isIntervalTimeComplete(unsigned long)'
firmware.cpp:172: undefined reference to `ReadingSync::isFirstSamplingLoop()'
firmware.cpp:175: undefined reference to `SensorBase::isSamplingComplete()'
firmware.cpp:176: undefined reference to `TGS2602::getSewerGasPercentage(float)'
firmware.cpp:177: undefined reference to `ReadingSync::setSamplingComplete()'
../../../build/target/user/platform-6/libuser.a(firmware.o): In function `HttpClient::get(http_request_t&, http_response_t&)':
../libs/HttpClient/HttpClient.h:77: undefined reference to `HttpClient::request(http_request_t&, http_response_t&, http_header_t*, char const*)'
firmware.cpp:209: undefined reference to `ReadingSync::setReadingSent()'
firmware.cpp:217: undefined reference to `SensorBase::startCalibrating()'
firmware.cpp:219: undefined reference to `TGS2602::calibrateInCleanAir(int)'
firmware.cpp:221: undefined reference to `ReadingSync::setCalibratingComplete()'
firmware.cpp:223: undefined reference to `SimpleEeprom::writeFloat(float, int)'
firmware.cpp:234: undefined reference to `ReadingSync::isFirstPreHeatLoop()'
firmware.cpp:244: undefined reference to `RgbLedControl::setLedColor(int, int, int, RgbLedControl::Color)'
firmware.cpp:125: undefined reference to `SensorBase::setAnalogRead(int, unsigned long)'
../../../build/target/user/platform-6/libuser.a(firmware.o): In function `__static_initialization_and_destruction_0':
firmware.cpp:55: undefined reference to `PietteTech_DHT::PietteTech_DHT(unsigned char, unsigned char, void (*)())'
firmware.cpp:64: undefined reference to `Adafruit_SSD1306::Adafruit_SSD1306(signed char)'
firmware.cpp:69: undefined reference to `HttpClient::HttpClient()'
make: *** [60d405f5bdabade0c061b3fb68ccc595afbab70eed41bc204550108a8ec9.elf] Error 1
build failed
