Building modules on the Core
Hi,Everyone.
I am a beginner here. I got a Core,and I connected it to my local cloud(spark-server).
It works,I can light on the led and light off led by using particle command.
I can see
on ready { coreID: ‘XXXXXXXXXXXXXXXXXXX’,
ip: ‘XXXXXXXXXXXXXXX’,
product_id: 0,
firmware_version: 7,
cache_key: ‘_0’ }
Core online!
on server’s console.
When I try to build the latest fw,
sudo make
or
sudo make PLATFORM=core
it print
makefile:20: *** “Platform ‘core’ does not support dynamic modules”
I try to using firmware-0.4.6.1.zip,but it with the same problem.
Could anyone tell me, Should I get other version(What version == 7)?
or modify config on latest version,or some command?
The Core doesn’t support modular firmware. To build for the core, be sure you start from the main directory, rather than modules.
Thanks.
