In Build >Devices>[Device]> Signal, when pressed an icon of a flashing bulb appears in the lower right corner. But the device remains unchanged. Just the slow breathing blue showing a connection (which is confirmed in the Console).
I think I am supposed to see an “animated Led” on the board. Why wouldn’t I?
Also, Build tells me that I have flashed firmware when I make a project, yet here too I see nothing change on the board. No purple led color or otherwise when flashed. Just the connected led blue breathing.
I am certainly having troubles as a Noob.
thanks
