#include "HttpClient/HttpClient.h"
#include "spark-dallas-temperature/spark-dallas-temperature.h"
#include "OneWire/OneWire.h"
#define ONE_WIRE_BUS D2 // Data wire is plugged into port 2 on the Particle Photon
#define TEMPERATURE_PRECISION 9 // Temperature precision is set to 9
// HttpClient initialization
HttpClient http;
http_header_t headers[] = {
{ "Content-Type", "application/json" },
{ "Accept" , "application/json" },
{ "Accept" , "*/*"},
http_request_t request;
http_response_t response;
// Setup a oneWire instance to communicate with any OneWire devices (not just Maxim/Dallas temperature ICs)
OneWire oneWire(ONE_WIRE_BUS);
// Declaring variables
double tempC = 0.0;
// Customize this variable if you need to change interval between data send actions
int interval_seconds = 300; // Seconds of interval between updates
// OTA status
String ota_status;
String method; // Currently only "get" and "post" are implemented
String hostname;
int port;
String path;
// sendHttpRequest function
void sendHttpRequest(String method, String hostname, int port, String path, String body)
request.hostname = hostname;
request.port = port;
request.path = path;
request.body = body;
Serial.print("Method: " + method + "\n");
Serial.print("Hostname: " + hostname + "\n");
Serial.print("Port: " + String(port) + "\n");
Serial.print("Path: " + path + "\n");
Serial.print("Body: " + body + "\n");
if (method == "post") {
Serial.print("\nSending http request\n");
http.post(request, response, headers);
Serial.print("Application>\tResponse status: ");
Serial.println(response.status);
Serial.print("Application>\tHTTP Response Body: ");
Serial.println(response.body);
} else if (method == "get") {
http.get(request, response, headers);
} else {
Serial.print("Please check your method: only post and get are currently supported");
// Pass our oneWire reference to Dallas Temperature.
DallasTemperature sensors(&oneWire);
// Arrays to hold device addresses
DeviceAddress sensor1, sensor2, sensor3;
void setup(void)
sensors.begin();
Serial.begin(9600); // Start serial port
Serial.println("Temperature Sensors");
// Start up the library
sensors.begin();
// Locate devices on the bus
Serial.print("Locating devices...");
Serial.print("Found ");
Serial.print(sensors.getDeviceCount(), DEC);
Serial.println(" devices.");
// Report parasite power requirements
Serial.print("Parasite power is: ");
if (sensors.isParasitePowerMode()) Serial.println("ON");
else Serial.println("OFF");
if (!sensors.getAddress(sensor1, 0)) Serial.println("Unable to find address for Device 0");
if (!sensors.getAddress(sensor2, 1)) Serial.println("Unable to find address for Device 1");
if (!sensors.getAddress(sensor3, 2)) Serial.println("Unable to find address for Device 2");
// Set the resolution to 9 bit
sensors.setResolution(sensor1, TEMPERATURE_PRECISION);
sensors.setResolution(sensor2, TEMPERATURE_PRECISION);
sensors.setResolution(sensor3, TEMPERATURE_PRECISION);
void loop(void)
// Call sensors.requestTemperatures() to issue a global temperature request to all devices on the bus
Serial.print("Requesting temperatures...");
sensors.requestTemperatures();
Serial.println("DONE");
// Getting sensor 1 temperature
delay (3000); // Wait to allow the sensor to be online
tempC = sensors.getTempCByIndex(0);
int try_number = 0; // Variable used to count how many times the temp is reread in case of a bad value
// Handle bad tempC value
while (try_number < 6) {
if (tempC == -127 || tempC == 85) {
delay (1000); // Wait to allow the sensor to be online
sendHttpRequest("get", "myip", 8080, "/ota/notification/temp_error", "");
try_number++;
try_number = 0;
break;
Serial.print("Sensor1: ");
Serial.print(tempC);
// Adding sensor 1 temperature to JSON result string
String resultstr;
resultstr = "{\"customer_1\": {\"sensor_1_temp\":";
resultstr += String(tempC);
// Getting sensor 2 temperature
tempC = sensors.getTempCByIndex(1);
try_number++;
try_number = 0;
break;
Serial.print("Sensor2: ");
// Adding sensor 2 temperature to JSON result string
resultstr += ", \"sensor_2_temp\":";
// Getting sensor 3 temperature
tempC = sensors.getTempCByIndex(2);
try_number++;
try_number = 0;
break;
Serial.print("Sensor3: ");
// adding sensor 3 temperature to JSON result string
resultstr += ", \"sensor_3_temp\":";
// adding wifi signal data
resultstr += ", \"wifi_strenght\":";
resultstr += String(WiFi.RSSI());
// close JSON
resultstr += "}}";
// sending out data using httpclient
Serial.print("Sending data out...");
sendHttpRequest("post", "myip", 80, "/sensor/test", resultstr);
// Debug
//sendHttpRequest("post", "myip", 8080, "/post_print", resultstr;
// Check if OTA is enabled via http
sendHttpRequest("get", "myip", 8080, "/ota", "");
ota_status = response.body;
// Check if WiFi is connected, if not try to connect
if (!WiFi.ready()) {
WiFi.connect();
delay(10000);
sendHttpRequest("get", "168.235.144.244", 8080, "/ota/notification/wifi_error", "");
// Check if Particle cloud is connected, if not try to connect
if (!Particle.connected()) {
Particle.connect();
delay(10000);
sendHttpRequest("get", "myip", 8080, "/ota/notification/particle_cloud_error", "");
// Check if OTA update is enabled
if (ota_status=="off") {
// Turn off onboard led to show user that Photon is NOT in OTA update mode
digitalWrite(D7, LOW);
// Put Particle Photon in deep sleep for number of seconds specified in interval_seconds
System.sleep(SLEEP_MODE_DEEP,interval_seconds);
} else {
// Turn on onboard led to show user that Photon is in OTA update mode
digitalWrite(D7, HIGH);
// Send notification
Serial.print("Application>\tSending OTA on notification to user");
// Delay number of seconds specified in interval_seconds (delay function accepts a value in milliseconds that is why * 1000)
delay(interval_seconds * 1000);
Thanks for taking time to checking it
