Looking at the Electron’s eagle files on github, it appears there are three tiny pads on the bottom near pins A1-A2 that run to the RGB status LED. Could I use this to breakout the status led? Is there another/easier way to breakout the status led? Thanks
If you have spare GPIO pins, you can consider this:
Thanks for the help!
