Good morning. I have several projects with BORON. The detail is that in my country, in the BRAZIL case, it appears on the site as not recommended because of the coverage. Can someone from Particle let me know if there is a prospect of global chip coverage for my country.
The BRN314 does work in Brazil, however it is not recommended.
The local carriers in Brazil do not allow permanent roaming with the Particle EtherSIM. Thus at any time they can block access from your device and it will no longer connect to cellular, so we do not recommend using the Boron at all in Brazil.
