We are trying to get the embedded SIM card of Boron314 connected but it does not. I followed cellular connectivity troubleshooting guide. here is the doctor firmware log.
0000006780 [ncp.at] TRACE: > AT+COPS?
0000006782 [ncp.at] TRACE: < +COPS: 0
0000006783 [ncp.at] TRACE: < OK
0000006784 [ncp.at] TRACE: > AT+CREG?
0000006786 [ncp.at] TRACE: < +CREG: 2,0
0000006787 [ncp.at] TRACE: < OK
0000006788 [ncp.at] TRACE: > AT+CGREG?
0000006792 [ncp.at] TRACE: < +CGREG: 2,0
0000006792 [ncp.at] TRACE: < OK
0000021893 [ncp.at] TRACE: > AT+CEER
0000021896 [ncp.at] TRACE: < +CEER: "No report available"
0000021897 [ncp.at] TRACE: < OK
0000021898 [ncp.at] TRACE: > AT+CREG?
0000021901 [ncp.at] TRACE: < +CREG: 2,0
0000021902 [ncp.at] TRACE: < OK
0000021903 [ncp.at] TRACE: > AT+CGREG?
0000021906 [ncp.at] TRACE: < +CGREG: 2,0
0000021907 [ncp.at] TRACE: < OK
0000021908 [ncp.at] TRACE: > AT+CSQ
0000021911 [ncp.at] TRACE: < +CSQ: 31,1
0000021912 [ncp.at] TRACE: < OK
0000029166 [app] INFO: Disconnecting before tower scan
0000029167 [app] INFO: Disconecting from celluar...
0000029169 [app] INFO: Turning cellular off...
0000029170 [net.pppncp] ERROR: Failed to initialize cellular NCP client: -210
0000029171 [net.ppp.client] TRACE: PPP thread event LOWER_DOWN data=0
0000029172 [net.ppp.client] TRACE: PPP thread event ADM_DOWN data=0
0000029173 [net.ppp.client] TRACE: State READY -> NONE
0000029172 [net.pppncp] TRACE: NCP event 3
0000029175 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_POWERING_DOWN
0000029176 [system.nm] TRACE: Interface 4 power state changed: 3
0000029176 [ncp.client] TRACE: Try powering modem off using AT command
0000029178 [ncp.at] TRACE: > AT+CPWROFF
0000029180 [system.nm] INFO: State changed: IFACE_UP -> IFACE_REQUEST_DOWN
0000029182 [system.nm] INFO: State changed: IFACE_REQUEST_DOWN -> IFACE_DOWN
0000029184 [system.nm] INFO: State changed: IFACE_DOWN -> IFACE_REQUEST_UP
0000029186 [system.nm] INFO: State changed: IFACE_REQUEST_UP -> IFACE_UP
0000029225 [mux] INFO: Stopping GSM07.10 muxer
0000029226 [mux] INFO: Gracefully stopping GSM07.10 muxer
0000029227 [mux] INFO: Closing all muxed channels
0000029227 [mux] INFO: Closing mux channel 1
0000029228 [mux] INFO: Muxed channel 2 already closed
0000029229 [mux] INFO: Muxed channel 3 already closed
0000029230 [mux] INFO: Muxed channel 4 already closed
0000029230 [mux] INFO: GSM07.10 muxer thread exiting
0000029231 [mux] INFO: GSM07.10 muxer stopped
0000029232 [ncp.client] TRACE: Setting UART voltage translator state 0
0000029233 [ncp.client] TRACE: Powering modem off using hardware control
0000029233 [ncp.client] TRACE: Setting UART voltage translator state 0
0000029235 [system.nm] INFO: State changed: IFACE_UP -> IFACE_REQUEST_DOWN
0000029237 [system.nm] INFO: State changed: IFACE_REQUEST_DOWN -> IFACE_DOWN
0000029243 [system.nm] TRACE: Request to power off the interface
0000029244 [system.nm] INFO: State changed: IFACE_DOWN -> DISABLED
0000031948 [net.pppncp] TRACE: NCP event 3
0000031949 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_DOWN
0000031950 [system.nm] TRACE: Interface 4 power state changed: 1
0000031950 [ncp.client] TRACE: Modem powered off
0000031951 [ncp.client] TRACE: Deinit modem serial.
0000031952 [ncp.client] TRACE: Modem already off
0000031952 [ncp.client] TRACE: Setting UART voltage translator state 0
0000031953 [ncp.client] TRACE: Soft power off modem successfully
0000031954 [ncp.client] TRACE: Deinit modem serial.
0000031954 [ncp.client] TRACE: NCP connection state changed: 0
0000031955 [net.pppncp] TRACE: NCP event 2
0000031956 [net.pppncp] TRACE: State changed event: 0
0000031956 [net.ppp.client] TRACE: PPP thread event LOWER_DOWN data=0
0000031956 [ncp.client] TRACE: NCP state changed: 0
0000031958 [net.pppncp] TRACE: NCP event 1
0000031958 [app] INFO: Turning cellular on...
0000031960 [system.nm] TRACE: Request to power on the interface
0000031961 [ncp.client] TRACE: Powering modem on, ncpId: 0x42
0000031962 [net.pppncp] TRACE: NCP event 3
0000031962 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_POWERING_UP
0000031964 [system.nm] INFO: State changed: DISABLED -> IFACE_DOWN
0000031967 [system.nm] INFO: State changed: IFACE_DOWN -> IFACE_REQUEST_UP
0000031969 [system.nm] INFO: State changed: IFACE_REQUEST_UP -> IFACE_UP
0000031972 [net.pppncp] TRACE: NCP event 3
0000031973 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_UP
0000031974 [system.nm] TRACE: Interface 4 power state changed: 2
0000031975 [ncp.client] TRACE: Modem powered on
0000031975 [ncp.client] TRACE: Setting UART voltage translator state 1
0000032075 [ncp.client] TRACE: Setting UART voltage translator state 0
0000032175 [ncp.client] TRACE: Setting UART voltage translator state 1
0000033176 [ncp.at] TRACE: > AT
0000034177 [ncp.at] TRACE: > AT
0000035178 [ncp.at] TRACE: > AT
0000036179 [ncp.at] TRACE: > AT
0000036182 [ncp.at] TRACE: < OK
0000036182 [ncp.client] TRACE: NCP ready to accept AT commands
0000036183 [ncp.at] TRACE: > AT
0000036185 [ncp.at] TRACE: < OK
0000036186 [ncp.at] TRACE: > ATI9
0000036200 [ncp.at] TRACE: < 23.60,A01.01
0000036200 [ncp.at] TRACE: < OK
0000036201 [ncp.client] TRACE: App firmware: 101
0000036201 [ncp.at] TRACE: > AT+UGPIOC?
0000036205 [ncp.at] TRACE: < +UGPIOC:
0000036206 [ncp.at] TRACE: < 16,255
0000036207 [ncp.at] TRACE: < 23,255
0000036207 [ncp.at] TRACE: < 24,4
0000036208 [ncp.at] TRACE: < 25,5
0000036209 [ncp.at] TRACE: < 34,12
0000036209 [ncp.at] TRACE: < 35,12
0000036210 [ncp.at] TRACE: < 36,12
0000036211 [ncp.at] TRACE: < 37,12
0000036211 [ncp.at] TRACE: < 42,7
0000036212 [ncp.at] TRACE: < OK
0000036213 [ncp.client] INFO: Using internal SIM card
0000036213 [ncp.at] TRACE: > AT+CPIN?
0000036217 [ncp.at] TRACE: < ERROR
0000036230 [app] INFO: CPIN ERROR
0000037217 [ncp.at] TRACE: > AT+CPIN?
0000037222 [ncp.at] TRACE: < +CPIN: READY
0000037223 [ncp.at] TRACE: < OK
0000037223 [ncp.at] TRACE: > AT+CCID
0000037307 [ncp.at] TRACE: < +CCID: 89883070000006620171
0000037308 [ncp.at] TRACE: < OK
0000037309 [ncp.at] TRACE: > AT+IFC?
0000037313 [ncp.at] TRACE: < +IFC: 2,2
0000037313 [ncp.at] TRACE: < OK
0000037314 [ncp.at] TRACE: > AT+IFC=2,2
0000037317 [ncp.at] TRACE: < OK
0000037318 [ncp.at] TRACE: > AT
0000038318 [ncp.at] TRACE: > AT
0000038321 [ncp.at] TRACE: < OK
0000038321 [ncp.at] TRACE: > AT+IPR=921600
0000038325 [ncp.at] TRACE: < OK
0000039326 [ncp.at] TRACE: > AT
0000039328 [ncp.at] TRACE: < OK
0000039329 [ncp.at] TRACE: > AT+COPS=3,2
0000039331 [ncp.at] TRACE: < OK
0000039331 [ncp.at] TRACE: > AT+CGEREP=1,0
0000039334 [ncp.at] TRACE: < OK
0000039335 [ncp.at] TRACE: > AT+UPSV=0
0000039337 [ncp.at] TRACE: < OK
0000039338 [ncp.at] TRACE: > AT+CMUX=0,0,,1509,,,,,
0000039466 [ncp.at] TRACE: < OK
0000039467 [mux] INFO: Starting GSM07.10 muxer
0000039468 [mux] INFO: Openning mux channel 0
0000039468 [mux] INFO: GSM07.10 muxer thread started
0000039471 [mux] INFO: Openning mux channel 1
0000039475 [ncp.at] TRACE: > AT
0000039477 [ncp.at] TRACE: < OK
0000039478 [ncp.client] TRACE: NCP state changed: 1
0000039478 [net.pppncp] TRACE: NCP event 1
0000039479 [net.ppp.client] TRACE: PPP thread event ADM_UP data=0
0000039480 [net.ppp.client] TRACE: State NONE -> READY
0000039483 [ncp.at] TRACE: > AT
0000039484 [app] INFO: Looking up operators (this may take up to 3 minutes)...
0000039485 [ncp.at] TRACE: < OK
0000039487 [ncp.at] TRACE: > AT+CFUN?
0000039489 [ncp.at] TRACE: < +CFUN: 1,0
0000039490 [ncp.at] TRACE: < OK
0000039491 [ncp.at] TRACE: > AT+CCID
0000040032 [ncp.at] TRACE: < +CCID: 89883070000006620171
0000040033 [ncp.at] TRACE: < OK
0000040034 [ncp.at] TRACE: > AT+CGDCONT?
0000040037 [ncp.at] TRACE: < +CGDCONT: 1,"IP","super","0.0.0.0",0,0
0000040039 [ncp.at] TRACE: < OK
0000040040 [ncp.at] TRACE: > AT+CFUN?
0000040042 [ncp.at] TRACE: < +CFUN: 1,0
0000040043 [ncp.at] TRACE: < OK
0000040044 [ncp.at] TRACE: > AT+CREG=2
0000040047 [ncp.at] TRACE: < OK
0000040048 [ncp.at] TRACE: > AT+CGREG=2
0000040051 [ncp.at] TRACE: < OK
0000040051 [ncp.client] TRACE: NCP connection state changed: 1
0000040052 [net.pppncp] TRACE: NCP event 2
0000040053 [net.pppncp] TRACE: State changed event: 1
0000040053 [net.ppp.client] TRACE: PPP thread event LOWER_DOWN data=0
0000040055 [ncp.at] TRACE: > AT+COPS?
0000040057 [ncp.at] TRACE: < +COPS: 0
0000040058 [ncp.at] TRACE: < OK
0000040059 [ncp.at] TRACE: > AT+CREG?
0000040062 [ncp.at] TRACE: < +CREG: 2,0
0000040063 [ncp.at] TRACE: < OK
0000040064 [ncp.at] TRACE: > AT+CGREG?
0000040068 [ncp.at] TRACE: < +CGREG: 2,0
0000040069 [ncp.at] TRACE: < OK
0000040071 [ncp.at] TRACE: > AT+COPS=5
0000070369 [ncp.at] TRACE: < MCC:422, MNC:02, LAC:c3b6, RAC:4, CI:1f56df9, DLF: 3005, ULF: 2780, SC
0000070372 [app] INFO: rat=UMTS mcc=422, mnc=2, lac=c3b6 ci=1f56df9 band=UMTS 900 rssi=-53 dlf=3005
0000072602 [ncp.at] TRACE: < MCC:422, MNC:03, LAC:336c, RAC:1, CI:00b90d0, DLF: 3075, ULF: 2850, SC
0000072605 [app] INFO: rat=UMTS mcc=422, mnc=3, lac=336c ci=b90d0 band=UMTS 900 rssi=-74 dlf=3075 u
0000073188 [ncp.at] TRACE: < MCC:422, MNC:03, LAC:336c, RAC:1, CI:00b5d55, DLF: 3075, ULF: 2850, SC
0000073190 [app] INFO: rat=UMTS mcc=422, mnc=3, lac=336c ci=b5d55 band=UMTS 900 rssi=-77 dlf=3075 u
0000073828 [ncp.at] TRACE: < MCC:422, MNC:03, LAC:336c, RAC:1, CI:00b6647, DLF: 3075, ULF: 2850, SC
0000073830 [app] INFO: rat=UMTS mcc=422, mnc=3, lac=336c ci=b6647 band=UMTS 900 rssi=-80 dlf=3075 u
0000075107 [ncp.at] TRACE: < MCC:422, MNC:03, LAC:336c, RAC:1, CI:00b5a97, DLF: 3075, ULF: 2850, SC
0000075109 [app] INFO: rat=UMTS mcc=422, mnc=3, lac=336c ci=b5a97 band=UMTS 900 rssi=-84 dlf=3075 u
0000077790 [ncp.at] TRACE: < MCC:422, MNC:02, LAC:c3b6, RAC:4, CI:1f56ddb, DLF:10687, ULF: 9737, SC
0000077792 [app] INFO: rat=UMTS mcc=422, mnc=2, lac=c3b6 ci=1f56ddb band=UMTS 2100 rssi=-74 dlf=106
0000079642 [ncp.at] TRACE: < MCC:422, MNC:03, LAC:336c, RAC:1, CI:00b90d5, DLF: 3050, ULF: 2825, SC
0000079644 [app] INFO: rat=UMTS mcc=422, mnc=3, lac=336c ci=b90d5 band=UMTS 900 rssi=-78 dlf=3050 u
0000080282 [ncp.at] TRACE: < MCC:422, MNC:03, LAC:336c, RAC:1, CI:00b90d4, DLF: 3050, ULF: 2825, SC
0000080284 [app] INFO: rat=UMTS mcc=422, mnc=3, lac=336c ci=b90d4 band=UMTS 900 rssi=-85 dlf=3050 u
0000082148 [ncp.at] TRACE: < MCC:422, MNC:03, LAC:336c, RAC:3, CI:00b0a03, DLF:10562, ULF: 9612, SC
0000082150 [app] INFO: rat=UMTS mcc=422, mnc=3, lac=336c ci=b0a03 band=UMTS 2100 rssi=-97 dlf=10562
0000082788 [ncp.at] TRACE: < MCC:422, MNC:03, LAC:336c, RAC:3, CI:00b214c, DLF:10562, ULF: 9612, SC
0000082790 [app] INFO: rat=UMTS mcc=422, mnc=3, lac=336c ci=b214c band=UMTS 2100 rssi=-103 dlf=1056
0000083427 [ncp.at] TRACE: < MCC:422, MNC:03, LAC:336c, RAC:1, CI:00b355d, DLF:10562, ULF: 9612, SC
0000083429 [app] INFO: rat=UMTS mcc=422, mnc=3, lac=336c ci=b355d band=UMTS 2100 rssi=-106 dlf=1056
0000190895 [ncp.at] TRACE: < OK
0000190896 [ncp.at] TRACE: > AT+CIMI
0000190898 [ncp.at] TRACE: < +CREG: 4
0000190899 [ncp.at] TRACE: < +CGREG: 4
0000190900 [ncp.at] TRACE: < 232104850659160
0000190901 [ncp.at] TRACE: < OK
0000190902 [ncp.at] TRACE: > AT+CEER
0000190904 [ncp.at] TRACE: < +CEER: "No report available"
0000190905 [ncp.at] TRACE: < OK
0000190906 [ncp.at] TRACE: > AT+CREG?
0000190909 [ncp.at] TRACE: < +CREG: 2,4
0000190910 [ncp.at] TRACE: < OK
0000190911 [ncp.at] TRACE: > AT+CGREG?
0000190914 [ncp.at] TRACE: < +CGREG: 2,4
0000190915 [ncp.at] TRACE: < OK
0000190916 [ncp.at] TRACE: > AT+CSQ
0000190919 [ncp.at] TRACE: < +CSQ: 99,99
0000190919 [ncp.at] TRACE: < OK
0000198119 [ncp.at] TRACE: < +CREG: 3
0000198219 [ncp.at] TRACE: < +CGREG: 3
0000199119 [ncp.at] TRACE: < +CREG: 0
0000199219 [ncp.at] TRACE: < +CGREG: 0
0000199819 [ncp.at] TRACE: < +UMWI: 0,1
0000199820 [ncp.at] TRACE: < +UMWI: 0,2
0000199820 [ncp.at] TRACE: < +UMWI: 0,3
0000199821 [ncp.at] TRACE: < +UMWI: 0,4
0000205922 [ncp.at] TRACE: > AT+CEER
0000205925 [ncp.at] TRACE: < +CEER: "No report available"
0000205926 [ncp.at] TRACE: < OK
0000205927 [ncp.at] TRACE: > AT+CREG?
0000205930 [ncp.at] TRACE: < +CREG: 2,0
0000205931 [ncp.at] TRACE: < OK
0000205932 [ncp.at] TRACE: > AT+CGREG?
0000205935 [ncp.at] TRACE: < +CGREG: 2,0
0000205935 [ncp.at] TRACE: < OK
0000205936 [ncp.at] TRACE: > AT+CSQ
0000205939 [ncp.at] TRACE: < +CSQ: 31,1
0000205940 [ncp.at] TRACE: < OK
0000221041 [ncp.at] TRACE: > AT+CEER
0000221044 [ncp.at] TRACE: < +CEER: "No report available"
0000221045 [ncp.at] TRACE: < OK
0000221046 [ncp.at] TRACE: > AT+CREG?
0000221049 [ncp.at] TRACE: < +CREG: 2,0
0000221049 [ncp.at] TRACE: < OK
0000221050 [ncp.at] TRACE: > AT+CGREG?
0000221053 [ncp.at] TRACE: < +CGREG: 2,0
0000221054 [ncp.at] TRACE: < OK
0000221055 [ncp.at] TRACE: > AT+CSQ
0000221058 [ncp.at] TRACE: < +CSQ: 31,1
0000221058 [ncp.at] TRACE: < OK
0000225258 [ncp.at] TRACE: < +CREG: 3
0000225358 [ncp.at] TRACE: < +CGREG: 3
0000236159 [ncp.at] TRACE: > AT+CEER
0000236162 [ncp.at] TRACE: < +CEER: "No report available"
0000236163 [ncp.at] TRACE: < OK
0000236164 [ncp.at] TRACE: > AT+CREG?
0000236166 [ncp.at] TRACE: < +CREG: 2,3
0000236167 [ncp.at] TRACE: < OK
0000236168 [ncp.at] TRACE: > AT+CGREG?
0000236171 [ncp.at] TRACE: < +CGREG: 2,3
0000236172 [ncp.at] TRACE: < OK
0000236173 [ncp.at] TRACE: > AT+CSQ
0000236175 [ncp.at] TRACE: < +CSQ: 31,1
0000236176 [ncp.at] TRACE: < OK
0000250977 [ncp.at] TRACE: > AT+CIMI
0000250980 [ncp.at] TRACE: < 234500011597719
0000250981 [ncp.at] TRACE: < OK
0000251181 [ncp.at] TRACE: > AT+CEER
0000251184 [ncp.at] TRACE: < +CEER: "No report available"
0000251186 [ncp.at] TRACE: < OK
0000251186 [ncp.at] TRACE: > AT+CREG?
0000251189 [ncp.at] TRACE: < +CREG: 2,3
0000251190 [ncp.at] TRACE: < OK
0000251191 [ncp.at] TRACE: > AT+CGREG?
0000251194 [ncp.at] TRACE: < +CGREG: 2,3
0000251195 [ncp.at] TRACE: < OK
0000251196 [ncp.at] TRACE: > AT+CSQ
0000251199 [ncp.at] TRACE: < +CSQ: 31,1
0000251199 [ncp.at] TRACE: < OK
0000266300 [ncp.at] TRACE: > AT+CEER
0000266303 [ncp.at] TRACE: < +CEER: "No report available"
0000266303 [ncp.at] TRACE: < OK
0000266305 [ncp.at] TRACE: > AT+CREG?
0000266307 [ncp.at] TRACE: < +CREG: 2,3
0000266308 [ncp.at] TRACE: < OK
0000266309 [ncp.at] TRACE: > AT+CGREG?
0000266312 [ncp.at] TRACE: < +CGREG: 2,3
0000266312 [ncp.at] TRACE: < OK
0000266313 [ncp.at] TRACE: > AT+CSQ
0000266316 [ncp.at] TRACE: < +CSQ: 31,1
0000266317 [ncp.at] TRACE: < OK
0000281417 [ncp.at] TRACE: > AT+CEER
0000281420 [ncp.at] TRACE: < +CEER: "No report available"
0000281421 [ncp.at] TRACE: < OK
0000281422 [ncp.at] TRACE: > AT+CREG?
0000281425 [ncp.at] TRACE: < +CREG: 2,3
0000281426 [ncp.at] TRACE: < OK
0000281427 [ncp.at] TRACE: > AT+CGREG?
0000281429 [ncp.at] TRACE: < +CGREG: 2,3
0000281430 [ncp.at] TRACE: < OK
0000281431 [ncp.at] TRACE: > AT+CSQ
0000281434 [ncp.at] TRACE: < +CSQ: 31,1
0000281435 [ncp.at] TRACE: < OK
0000296436 [ncp.at] TRACE: > AT+CEER
0000296439 [ncp.at] TRACE: < +CEER: "No report available"
0000296440 [ncp.at] TRACE: < OK
0000296441 [ncp.at] TRACE: > AT+CREG?
0000296443 [ncp.at] TRACE: < +CREG: 2,3
0000296444 [ncp.at] TRACE: < OK
0000296445 [ncp.at] TRACE: > AT+CGREG?
0000296448 [ncp.at] TRACE: < +CGREG: 2,3
0000296448 [ncp.at] TRACE: < OK
0000296449 [ncp.at] TRACE: > AT+CSQ
0000296452 [ncp.at] TRACE: < +CSQ: 31,1
0000296453 [ncp.at] TRACE: < OK
0000311054 [ncp.at] TRACE: > AT+CIMI
0000311057 [ncp.at] TRACE: < 234500011597719
0000311057 [ncp.at] TRACE: < OK
0000311458 [ncp.at] TRACE: > AT+CEER
0000311461 [ncp.at] TRACE: < +CEER: "No report available"
0000311462 [ncp.at] TRACE: < OK
0000311463 [ncp.at] TRACE: > AT+CREG?
0000311466 [ncp.at] TRACE: < +CREG: 2,3
0000311467 [ncp.at] TRACE: < OK
0000311468 [ncp.at] TRACE: > AT+CGREG?
0000311471 [ncp.at] TRACE: < +CGREG: 2,3
0000311471 [ncp.at] TRACE: < OK
0000311472 [ncp.at] TRACE: > AT+CSQ
0000311475 [ncp.at] TRACE: < +CSQ: 31,1
0000311476 [ncp.at] TRACE: < OK
0000326577 [ncp.at] TRACE: > AT+CEER
0000326580 [ncp.at] TRACE: < +CEER: "No report available"
0000326581 [ncp.at] TRACE: < OK
0000326582 [ncp.at] TRACE: > AT+CREG?
0000326585 [ncp.at] TRACE: < +CREG: 2,3
0000326586 [ncp.at] TRACE: < OK
0000326587 [ncp.at] TRACE: > AT+CGREG?
0000326590 [ncp.at] TRACE: < +CGREG: 2,3
0000326591 [ncp.at] TRACE: < OK
0000326592 [ncp.at] TRACE: > AT+CSQ
0000326595 [ncp.at] TRACE: < +CSQ: 31,1
0000326596 [ncp.at] TRACE: < OK
0000340095 [ncp.client] TRACE: Sticky CSD and PSD denied state for 114 s, RF reset
0000340097 [ncp.at] TRACE: > AT+CFUN=0,0
0000340128 [ncp.at] TRACE: < OK
0000340129 [ncp.at] TRACE: > AT+CFUN=1,0
0000340131 [ncp.at] TRACE: < +CREG: 0
0000340132 [ncp.at] TRACE: < +CGREG: 0
0000340137 [ncp.at] TRACE: < OK
0000341638 [ncp.at] TRACE: > AT+CEER
0000341641 [ncp.at] TRACE: < +CEER: "No report available"
0000341642 [ncp.at] TRACE: < OK
0000341643 [ncp.at] TRACE: > AT+CREG?
0000341646 [ncp.at] TRACE: < +CREG: 2,0
0000341647 [ncp.at] TRACE: < OK
0000341648 [ncp.at] TRACE: > AT+CGREG?
0000341651 [ncp.at] TRACE: < +CGREG: 2,0
0000341651 [ncp.at] TRACE: < OK
0000341652 [ncp.at] TRACE: > AT+CSQ
0000341656 [ncp.at] TRACE: < +CSQ: 99,99
0000341656 [ncp.at] TRACE: < OK
0000356658 [ncp.at] TRACE: > AT+CEER
0000356661 [ncp.at] TRACE: < +CEER: "No report available"
0000356662 [ncp.at] TRACE: < OK
0000356663 [ncp.at] TRACE: > AT+CREG?
0000356665 [ncp.at] TRACE: < +CREG: 2,0
0000356666 [ncp.at] TRACE: < OK
0000356667 [ncp.at] TRACE: > AT+CGREG?
0000356670 [ncp.at] TRACE: < +CGREG: 2,0
0000356670 [ncp.at] TRACE: < OK
0000356671 [ncp.at] TRACE: > AT+CSQ
0000356674 [ncp.at] TRACE: < +CSQ: 99,99
0000356675 [ncp.at] TRACE: < OK
0000370175 [ncp.client] TRACE: Sticky not registering CSD state for 30 s, PLMN reselection
0000370177 [ncp.at] TRACE: > AT+COPS=0,2
0000411723 [ncp.at] TRACE: < ERROR
0000411724 [ncp.at] TRACE: > AT+CIMI
0000411725 [ncp.at] TRACE: < +CREG: 3
0000411726 [ncp.at] TRACE: < +CGREG: 3
0000411727 [ncp.at] TRACE: < 732123200687026
0000411727 [ncp.at] TRACE: < OK
0000411728 [ncp.at] TRACE: > AT+CEER
0000411730 [ncp.at] TRACE: < +CEER: "No report available"
0000411731 [ncp.at] TRACE: < OK
0000411733 [ncp.at] TRACE: > AT+CREG?
0000411733 [ncp.at] TRACE: < +CREG: 0
0000411735 [ncp.at] TRACE: < +CGREG: 0
0000411736 [ncp.at] TRACE: < +CREG: 2,0
0000411736 [ncp.at] TRACE: < OK
0000411738 [ncp.at] TRACE: > AT+CGREG?
0000411739 [ncp.at] TRACE: < +CGREG: 2,0
0000411740 [ncp.at] TRACE: < OK
0000411741 [ncp.at] TRACE: > AT+CSQ
0000411743 [ncp.at] TRACE: < +CSQ: 22,2
0000411744 [ncp.at] TRACE: < OK
0000412444 [ncp.at] TRACE: < +UMWI: 0,1
0000412445 [ncp.at] TRACE: < +UMWI: 0,2
0000412445 [ncp.at] TRACE: < +UMWI: 0,3
0000412446 [ncp.at] TRACE: < +UMWI: 0,4
0000426747 [ncp.at] TRACE: > AT+CEER
0000426750 [ncp.at] TRACE: < +CEER: "No report available"
0000426751 [ncp.at] TRACE: < OK
0000426752 [ncp.at] TRACE: > AT+CREG?
0000426755 [ncp.at] TRACE: < +CREG: 2,0
0000426756 [ncp.at] TRACE: < OK
0000426757 [ncp.at] TRACE: > AT+CGREG?
0000426760 [ncp.at] TRACE: < +CGREG: 2,0
0000426760 [ncp.at] TRACE: < OK
0000426761 [ncp.at] TRACE: > AT+CSQ
0000426764 [ncp.at] TRACE: < +CSQ: 22,2
0000426765 [ncp.at] TRACE: < OK
0000441766 [ncp.at] TRACE: > AT+CEER
0000441769 [ncp.at] TRACE: < +CEER: "No report available"
0000441770 [ncp.at] TRACE: < OK
0000441771 [ncp.at] TRACE: > AT+CREG?
0000441774 [ncp.at] TRACE: < +CREG: 2,0
0000441775 [ncp.at] TRACE: < OK
0000441776 [ncp.at] TRACE: > AT+CGREG?
0000441779 [ncp.at] TRACE: < +CGREG: 2,0
0000441779 [ncp.at] TRACE: < OK
0000441780 [ncp.at] TRACE: > AT+CSQ
0000441783 [ncp.at] TRACE: < +CSQ: 22,2
0000441784 [ncp.at] TRACE: < OK
0000456784 [ncp.client] TRACE: Sticky not registering CSD state for 45 s, PLMN reselection
0000456786 [ncp.at] TRACE: > AT+COPS=0,2
0000456789 [ncp.at] TRACE: < ERROR
0000456790 [ncp.at] TRACE: > AT+CEER
0000456793 [ncp.at] TRACE: < +CEER: "No report available"
0000456794 [ncp.at] TRACE: < OK
0000456795 [ncp.at] TRACE: > AT+CREG?
0000456798 [ncp.at] TRACE: < +CREG: 2,0
0000456798 [ncp.at] TRACE: < OK
0000456799 [ncp.at] TRACE: > AT+CGREG?
0000456802 [ncp.at] TRACE: < +CGREG: 2,0
0000456803 [ncp.at] TRACE: < OK
0000456804 [ncp.at] TRACE: > AT+CSQ
0000456807 [ncp.at] TRACE: < +CSQ: 22,2
0000456808 [ncp.at] TRACE: < OK
0000471808 [ncp.at] TRACE: > AT+CIMI
0000471811 [ncp.at] TRACE: < 732123200687026
0000471812 [ncp.at] TRACE: < OK
0000471813 [ncp.at] TRACE: > AT+CEER
0000471816 [ncp.at] TRACE: < +CEER: "No report available"
0000471817 [ncp.at] TRACE: < OK
0000471818 [ncp.at] TRACE: > AT+CREG?
0000471820 [ncp.at] TRACE: < +CREG: 2,0
0000471821 [ncp.at] TRACE: < OK
0000471822 [ncp.at] TRACE: > AT+CGREG?
0000471825 [ncp.at] TRACE: < +CGREG: 2,0
0000471826 [ncp.at] TRACE: < OK
0000471827 [ncp.at] TRACE: > AT+CSQ
0000471829 [ncp.at] TRACE: < +CSQ: 31,1
0000471830 [ncp.at] TRACE: < OK
0000479630 [ncp.at] TRACE: < +CREG: 3
0000479730 [ncp.at] TRACE: < +CGREG: 3
0000486931 [ncp.at] TRACE: > AT+CEER
0000486935 [ncp.at] TRACE: < +CEER: "No report available"
0000486936 [ncp.at] TRACE: < OK
0000486937 [ncp.at] TRACE: > AT+CREG?
0000486940 [ncp.at] TRACE: < +CREG: 2,3
0000486940 [ncp.at] TRACE: < OK
0000486941 [ncp.at] TRACE: > AT+CGREG?
0000486945 [ncp.at] TRACE: < +CGREG: 2,3
0000486946 [ncp.at] TRACE: < OK
0000486947 [ncp.at] TRACE: > AT+CSQ
0000486949 [ncp.at] TRACE: < +CSQ: 31,1
0000486950 [ncp.at] TRACE: < OK
0000502051 [ncp.at] TRACE: > AT+CEER
0000502054 [ncp.at] TRACE: < +CEER: "No report available"
0000502055 [ncp.at] TRACE: < OK
0000502056 [ncp.at] TRACE: > AT+CREG?
0000502059 [ncp.at] TRACE: < +CREG: 2,3
0000502060 [ncp.at] TRACE: < OK
0000502061 [ncp.at] TRACE: > AT+CGREG?
0000502064 [ncp.at] TRACE: < +CGREG: 2,3
0000502064 [ncp.at] TRACE: < OK
0000502065 [ncp.at] TRACE: > AT+CSQ
0000502068 [ncp.at] TRACE: < +CSQ: 31,1
0000502069 [ncp.at] TRACE: < OK
0000517169 [ncp.at] TRACE: > AT+CEER
0000517172 [ncp.at] TRACE: < +CEER: "No report available"
0000517173 [ncp.at] TRACE: < OK
0000517174 [ncp.at] TRACE: > AT+CREG?
0000517176 [ncp.at] TRACE: < +CREG: 2,3
0000517177 [ncp.at] TRACE: < OK
0000517178 [ncp.at] TRACE: > AT+CGREG?
0000517180 [ncp.at] TRACE: < +CGREG: 2,3
0000517181 [ncp.at] TRACE: < OK
0000517182 [ncp.at] TRACE: > AT+CSQ
0000517185 [ncp.at] TRACE: < +CSQ: 24,5
0000517186 [ncp.at] TRACE: < OK
0000517286 [ncp.at] TRACE: < +CREG: 0
0000517386 [ncp.at] TRACE: < +CGREG: 0
0000517986 [ncp.at] TRACE: < +UMWI: 0,1
0000517987 [ncp.at] TRACE: < +UMWI: 0,2
0000517987 [ncp.at] TRACE: < +UMWI: 0,3
0000517988 [ncp.at] TRACE: < +UMWI: 0,4
0000531889 [ncp.at] TRACE: > AT+CIMI
0000531892 [ncp.at] TRACE: < 232104850659160
0000531893 [ncp.at] TRACE: < OK
0000532194 [ncp.at] TRACE: > AT+CEER
0000532197 [ncp.at] TRACE: < +CEER: "No report available"
0000532198 [ncp.at] TRACE: < OK
0000532199 [ncp.at] TRACE: > AT+CREG?
0000532202 [ncp.at] TRACE: < +CREG: 2,0
0000532202 [ncp.at] TRACE: < OK
0000532203 [ncp.at] TRACE: > AT+CGREG?
0000532206 [ncp.at] TRACE: < +CGREG: 2,0
0000532207 [ncp.at] TRACE: < OK
0000532208 [ncp.at] TRACE: > AT+CSQ
0000532211 [ncp.at] TRACE: < +CSQ: 24,5
0000532212 [ncp.at] TRACE: < OK
0000547312 [ncp.at] TRACE: > AT+CEER
0000547315 [ncp.at] TRACE: < +CEER: "No report available"
0000547316 [ncp.at] TRACE: < OK
0000547317 [ncp.at] TRACE: > AT+CREG?
0000547320 [ncp.at] TRACE: < +CREG: 2,0
0000547321 [ncp.at] TRACE: < OK
0000547322 [ncp.at] TRACE: > AT+CGREG?
0000547324 [ncp.at] TRACE: < +CGREG: 2,0
0000547325 [ncp.at] TRACE: < OK
0000547326 [ncp.at] TRACE: > AT+CSQ
0000547329 [ncp.at] TRACE: < +CSQ: 24,5
0000547329 [ncp.at] TRACE: < OK
0000562430 [ncp.at] TRACE: > AT+CEER
0000562433 [ncp.at] TRACE: < +CEER: "No report available"
0000562434 [ncp.at] TRACE: < OK
0000562435 [ncp.at] TRACE: > AT+CREG?
0000562437 [ncp.at] TRACE: < +CREG: 2,0
0000562438 [ncp.at] TRACE: < OK
0000562439 [ncp.at] TRACE: > AT+CGREG?
0000562442 [ncp.at] TRACE: < +CGREG: 2,0
0000562443 [ncp.at] TRACE: < OK
0000562444 [ncp.at] TRACE: > AT+CSQ
0000562446 [ncp.at] TRACE: < +CSQ: 24,5
0000562447 [ncp.at] TRACE: < OK
0000577347 [ncp.client] TRACE: Sticky not registering CSD state for 60 s, PLMN reselection
0000577349 [ncp.at] TRACE: > AT+COPS=0,2
0000577352 [ncp.at] TRACE: < ERROR
0000577453 [ncp.at] TRACE: > AT+CEER
0000577456 [ncp.at] TRACE: < +CEER: "No report available"
0000577457 [ncp.at] TRACE: < OK
0000577458 [ncp.at] TRACE: > AT+CREG?
0000577460 [ncp.at] TRACE: < +CREG: 2,0
0000577461 [ncp.at] TRACE: < OK
0000577462 [ncp.at] TRACE: > AT+CGREG?
0000577465 [ncp.at] TRACE: < +CGREG: 2,0
0000577466 [ncp.at] TRACE: < OK
0000577467 [ncp.at] TRACE: > AT+CSQ
0000577470 [ncp.at] TRACE: < +CSQ: 24,5
0000577471 [ncp.at] TRACE: < OK
0000586170 [ncp.at] TRACE: < +CREG: 3
0000586270 [ncp.at] TRACE: < +CGREG: 3
0000591971 [ncp.at] TRACE: > AT+CIMI
0000591974 [ncp.at] TRACE: < 232104850659160
0000591975 [ncp.at] TRACE: < OK
0000592476 [ncp.at] TRACE: > AT+CEER
0000592479 [ncp.at] TRACE: < +CEER: "No report available"
0000592480 [ncp.at] TRACE: < OK
0000592481 [ncp.at] TRACE: > AT+CREG?
0000592483 [ncp.at] TRACE: < +CREG: 2,3
0000592484 [ncp.at] TRACE: < OK
0000592485 [ncp.at] TRACE: > AT+CGREG?
0000592488 [ncp.at] TRACE: < +CGREG: 2,3
0000592488 [ncp.at] TRACE: < OK
0000592489 [ncp.at] TRACE: > AT+CSQ
0000592492 [ncp.at] TRACE: < +CSQ: 28,0
0000592493 [ncp.at] TRACE: < OK
0000602393 [ncp.at] TRACE: < +CREG: 0
0000602493 [ncp.at] TRACE: < +CGREG: 0
0000603093 [ncp.at] TRACE: < +UMWI: 0,1
0000603094 [ncp.at] TRACE: < +UMWI: 0,2
0000603094 [ncp.at] TRACE: < +UMWI: 0,3
0000603095 [ncp.at] TRACE: < +UMWI: 0,4
0000607496 [ncp.at] TRACE: > AT+CEER
0000607499 [ncp.at] TRACE: < +CEER: "No report available"
0000607500 [ncp.at] TRACE: < OK
0000607501 [ncp.at] TRACE: > AT+CREG?
0000607504 [ncp.at] TRACE: < +CREG: 2,0
0000607505 [ncp.at] TRACE: < OK
0000607506 [ncp.at] TRACE: > AT+CGREG?
0000607509 [ncp.at] TRACE: < +CGREG: 2,0
0000607510 [ncp.at] TRACE: < OK
0000607510 [ncp.at] TRACE: > AT+CSQ
0000607513 [ncp.at] TRACE: < +CSQ: 22,2
0000607514 [ncp.at] TRACE: < OK
0000622515 [ncp.at] TRACE: > AT+CEER
0000622518 [ncp.at] TRACE: < +CEER: "No report available"
0000622519 [ncp.at] TRACE: < OK
0000622520 [ncp.at] TRACE: > AT+CREG?
0000622523 [ncp.at] TRACE: < +CREG: 2,0
0000622523 [ncp.at] TRACE: < OK
0000622524 [ncp.at] TRACE: > AT+CGREG?
0000622527 [ncp.at] TRACE: < +CGREG: 2,0
0000622528 [ncp.at] TRACE: < OK
0000622529 [ncp.at] TRACE: > AT+CSQ
0000622531 [ncp.at] TRACE: < +CSQ: 22,2
0000622532 [ncp.at] TRACE: < OK
0000629832 [ncp.at] TRACE: < +CREG: 3
0000629932 [ncp.at] TRACE: < +CGREG: 3
0000637633 [ncp.at] TRACE: > AT+CEER
0000637636 [ncp.at] TRACE: < +CEER: "No report available"
0000637637 [ncp.at] TRACE: < OK
0000637638 [ncp.at] TRACE: > AT+CREG?
0000637641 [ncp.at] TRACE: < +CREG: 2,3
0000637642 [ncp.at] TRACE: < OK
0000637643 [ncp.at] TRACE: > AT+CGREG?
0000637646 [ncp.at] TRACE: < +CGREG: 2,3
0000637647 [ncp.at] TRACE: < OK
0000637648 [ncp.at] TRACE: > AT+CSQ
0000637651 [ncp.at] TRACE: < +CSQ: 30,1
0000637651 [ncp.at] TRACE: < OK
0000652052 [ncp.at] TRACE: > AT+CIMI
0000652055 [ncp.at] TRACE: < 234500011597719
0000652056 [ncp.at] TRACE: < OK
0000652657 [ncp.at] TRACE: > AT+CEER
0000652660 [ncp.at] TRACE: < +CEER: "No report available"
0000652661 [ncp.at] TRACE: < OK
0000652662 [ncp.at] TRACE: > AT+CREG?
0000652665 [ncp.at] TRACE: < +CREG: 2,3
0000652666 [ncp.at] TRACE: < OK
0000652667 [ncp.at] TRACE: > AT+CGREG?
0000652669 [ncp.at] TRACE: < +CGREG: 2,3
0000652670 [ncp.at] TRACE: < OK
0000652671 [ncp.at] TRACE: > AT+CSQ
0000652674 [ncp.at] TRACE: < +CSQ: 30,1
0000652675 [ncp.at] TRACE: < OK
0000652676 [ncp.client] WARN: Resetting the modem due to the network registration timeout
0000652677 [ncp.client] TRACE: NCP connection state changed: 0
0000652678 [net.pppncp] TRACE: NCP event 2
0000652678 [net.pppncp] TRACE: State changed event: 0
0000652679 [ncp.client] TRACE: NCP state changed: 0
0000652680 [net.pppncp] TRACE: NCP event 1
0000652680 [mux] INFO: Stopping GSM07.10 muxer
0000652679 [net.ppp.client] TRACE: PPP thread event LOWER_DOWN data=0
0000652681 [mux] INFO: Gracefully stopping GSM07.10 muxer
0000652683 [mux] INFO: Closing all muxed channels
0000652683 [mux] INFO: Closing mux channel 1
0000652684 [mux] INFO: Muxed channel 2 already closed
0000652685 [mux] INFO: Muxed channel 3 already closed
0000652686 [mux] INFO: Muxed channel 4 already closed
0000653952 [mux] INFO: Sending CLD (multiplexer close down)
0000653954 [mux] INFO: Received response to CLD or timed out, exiting multiplexed mode
0000653955 [mux] INFO: GSM07.10 muxer thread exiting
0000653956 [mux] INFO: GSM07.10 muxer stopped
0000653957 [net.pppncp] TRACE: NCP event 3
0000653957 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_POWERING_DOWN
0000653958 [system.nm] TRACE: Interface 4 power state changed: 3
0000653959 [ncp.client] TRACE: Powering modem off using hardware control
0000653960 [ncp.client] TRACE: Setting UART voltage translator state 0
0000655460 [net.pppncp] TRACE: NCP event 3
0000655461 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_DOWN
0000655462 [system.nm] TRACE: Interface 4 power state changed: 1
0000655462 [ncp.client] TRACE: Modem powered off
0000655562 [ncp.client] TRACE: Powering modem on, ncpId: 0x42
0000655563 [net.pppncp] TRACE: NCP event 3
0000655563 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_POWERING_UP
0000655564 [system.nm] TRACE: Interface 4 power state changed: 4
0000655574 [net.pppncp] TRACE: NCP event 3
0000655575 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_UP
0000655576 [system.nm] TRACE: Interface 4 power state changed: 2
0000655576 [ncp.client] TRACE: Modem powered on
0000655577 [ncp.client] TRACE: Setting UART voltage translator state 1
0000655677 [ncp.client] TRACE: Setting UART voltage translator state 0
0000655777 [ncp.client] TRACE: Setting UART voltage translator state 1
0000656778 [ncp.at] TRACE: > AT
0000657779 [ncp.at] TRACE: > AT
0000658780 [ncp.at] TRACE: > AT
0000659781 [ncp.at] TRACE: > AT
0000659784 [ncp.at] TRACE: < OK
0000659784 [ncp.client] TRACE: NCP ready to accept AT commands
0000659785 [ncp.at] TRACE: > AT
0000659787 [ncp.at] TRACE: < OK
0000659788 [ncp.at] TRACE: > ATI9
0000659804 [ncp.at] TRACE: < 23.60,A01.01
0000659804 [ncp.at] TRACE: < OK
0000659805 [ncp.client] TRACE: App firmware: 101
0000659806 [ncp.at] TRACE: > AT+UGPIOC?
0000659810 [ncp.at] TRACE: < +UGPIOC:
0000659811 [ncp.at] TRACE: < 16,255
0000659811 [ncp.at] TRACE: < 23,255
0000659812 [ncp.at] TRACE: < 24,4
0000659813 [ncp.at] TRACE: < 25,5
0000659813 [ncp.at] TRACE: < 34,12
0000659814 [ncp.at] TRACE: < 35,12
0000659815 [ncp.at] TRACE: < 36,12
0000659815 [ncp.at] TRACE: < 37,12
0000659816 [ncp.at] TRACE: < 42,7
0000659817 [ncp.at] TRACE: < OK
