Hi All,
I have a boron stuck trying to connect. Apologies in advance if this is a repost of an existing topic. I went through some other topics but still haven’t managed to solve the issue. I have attached a snippet of the debug logs below. I’m hoping to try understand a bit more from the logs below also.
0000415877 [ncp.at] TRACE: < OK
0000416178 [ncp.at] TRACE: > AT+CEER
0000416181 [ncp.at] TRACE: < +CEER: "No report available"
0000416181 [ncp.at] TRACE: < OK
0000416182 [ncp.at] TRACE: > AT+CREG?
0000416185 [ncp.at] TRACE: < +CREG: 2,3
0000416194 [app.help] INFO: Network registration (CREG) Status: registration denied (3)
0000416186 [ncp.at] TRACE: < OK
0000416187 [ncp.at] TRACE: > AT+CGREG?
0000416189 [ncp.at] TRACE: < +CGREG: 2,3
0000416198 [app.help] INFO: GPRS network (CGREG) Status: registration denied (3)
0000416190 [ncp.at] TRACE: < OK
0000423453 [app] INFO: Still trying to connect to cellular 06:40
0000423453 [app] INFO: Power source: VIN
0000423453 [app] INFO: Battery state: unknown, SoC: -1.00
0000428490 [ncp.client] TRACE: Sticky CSD and PSD denied state for 75 s, RF reset
0000428490 [ncp.at] TRACE: > AT+CFUN=0,0
0000428495 [app.help] INFO: Set module functionality (CFUN): minimum functionality (0)
0000428498 [app.help] INFO: Reset Mode: do not reset before setting fun (0)
0000428513 [ncp.at] TRACE: < OK
0000428514 [ncp.at] TRACE: > AT+CFUN=1,0
0000428518 [app.help] INFO: Set module functionality (CFUN): full functionality (1)
0000428521 [app.help] INFO: Reset Mode: do not reset before setting fun (0)
0000428514 [ncp.at] TRACE: < +CREG: 0
0000428524 [app.help] INFO: Network registration (CREG) Status: not registered, not searching (0)
0000428514 [ncp.at] TRACE: < +CGREG: 0
0000428527 [app.help] INFO: GPRS network (CGREG) Status: not registered, not searching (0)
0000428517 [ncp.at] TRACE: < OK
0000431218 [ncp.at] TRACE: > AT+CEER
0000431221 [ncp.at] TRACE: < +CEER: "No report available"
0000431222 [ncp.at] TRACE: < OK
0000431223 [ncp.at] TRACE: > AT+CREG?
0000431226 [ncp.at] TRACE: < +CREG: 2,0
0000431234 [app.help] INFO: Network registration (CREG) Status: not registered, not searching (0)
0000431226 [ncp.at] TRACE: < OK
0000431227 [ncp.at] TRACE: > AT+CGREG?
0000431230 [ncp.at] TRACE: < +CGREG: 2,0
0000431239 [app.help] INFO: GPRS network (CGREG) Status: not registered, not searching (0)
0000431231 [ncp.at] TRACE: < OK
0000433453 [app] INFO: Still trying to connect to cellular 06:50
0000433453 [app] INFO: Power source: VIN
0000433453 [app] INFO: Battery state: unknown, SoC: -1.00`
