Connectivity to Rogers has been very flaky since this morning - Borons will try to connect with flashing cyan, but can't connect. I raised a ticket through support. The last time I reported this issue was Jun 23, 2025
Thanks for confirming. As these are customer-impacting and weren't detected by the particle team, is there anything that can be improved to report these issues faster to you, so that they can be addressed within a faster response time?
Regional issues are typically short-lived and low impact - primarily caused by carrier upgrades/changes etc.
If it affects a broad portion of devices, our alerts will trigger and it will be escalated to the MVNO and from there to the carriers.
I'll send you a DM re. direct support.
