If I add an external WiFi board to the Boron (e.g. AirLift FeatherWing), am I able to choose how the Boron connects to the Particle cloud? I perused the API docs, but couldn’t find a solution.
@znjp, what you are looking for is not supported in DeviceOS. You can add an external WiFi board but it will not be able to connect to the Particle Cloud.
ah bummer, but thanks for the quick reply
