My LTE boron flashes the orange charge light at maybe 4hz when it goes to sleep. I’m not using a battery, the power supply is capable of 1.5A. The light turns off when the boron wakes up. I used this code to put it to sleep:
SystemSleepConfiguration config;
config.mode(SystemSleepMode::STOP)
.gpio(D5, RISING)
.duration(sleepDuration)
.network(NETWORK_INTERFACE_CELLULAR);
SystemSleepResult sleepResult = System.sleep(config);
//if the app wakes electron up, stay awake for 30s to communicate
if (sleepResult.wakeupReason() == SystemSleepWakeupReason::BY_NETWORK) {
// Waken by network activity
awakeDuration = 30000;
else
awakeDuration = 10000;
sleepDuration = 60;
and this code to disable charging, as found in another post:
void setCharging(bool enable) {
PMIC pmic;
// DisableCharging turns of charging. DisableBATFET completely disconnects the battery.
if (enable) {
pmic.enableCharging();
pmic.enableBATFET();
else {
pmic.disableCharging();
pmic.disableBATFET();
// Disabling the watchdog is necessary, otherwise it will kick in and turn
// charing at random times, even when sleeping.
// This disables both the watchdog and the charge safety timer in
// Charge Termination/Timer Control Register REG05
// pmic.disableWatchdog() disables the watchdog, but doesn't disable the
// charge safety timer, so the red LED will start blinking slowly after
// 1 hour if you don't do both.
byte DATA = pmic.readChargeTermRegister();
if (enable) {
DATA |= 0b00111000;
else {
// 0b11001110 = disable watchdog
// 0b11000110 = disable watchdog and charge safety timer
DATA &= 0b11000110;
// This would be easier if pmic.writeRegister wasn't private (or disable
// charge safety timer had an exposed method
Wire1.beginTransmission(PMIC_ADDRESS);
Wire1.write(CHARGE_TIMER_CONTROL_REGISTER);
Wire1.write(DATA);
Wire1.endTransmission(true);
Is there something else I need to do as well to keep the light off?
Another question related to sleep, the console can’t fetch variables when it is woken up. If I don’t put the boron to sleep the console retrieves them very quickly and reliably. However, I would like the boron to wake up from the request for a variable. System_Thread is enabled and I left it on the default automatic mode. Should there be a pause somehow after it wakes up for reconnection? I thought that since I’m not turning the modem off, it should be able to send the values back almost immediately.
